4020 transmission ques
tom
03-21-2004 02:15:43
Howdy,
Have a friend with a 1972 diesel 4020, w/ the power shift transmission. He said is makes a grinding noise in 3rd, 4th, 5th & 6th forward and 3rd & 4th backwards. There is no difference in the vibrations, but just the sound. Does anyone know that this could be or what needs to be checked or done?
Thanks,
tom
G-MAN
03-21-2004 14:08:11
 Re: 4020 transmission ques in reply to tom, 03-21-2004 02:15:43
As Mike said, it sounds like a problem with one of the clutch or brake elements. C2 clutch is common to all those speeds you mention, so I'd start with that. C2 is also used in 7th and 8th, but in conjunction with C1, which could change the sound. The tractor will need to be split at the clutch housing - just back of the engine - and have the clutch pack removed for disassembly and inspection. It could be a relatively "cheap" fix or pretty expensive, depending on what hard parts are damaged.
tom
03-24-2004 04:15:49
 Re: Re: 4020 transmission ques in reply to G-MAN, 03-21-2004 14:08:11
G-man,
Thank you for your follow-up. I have passed on the information and he really appreciated it.
Regards,
tom
Mike
03-21-2004 04:59:31
Sounds like he is losing a planetary set or clutch pack.Pull both filters and check for chips or a silvery paste.Don't run it anymore until the problem is fixed because whatever is grinding is putting metal particles in the oil which is being pumped through the whole trans and hydraulic system. As far as cost,it depends on the amount of damage to hard parts and the extent of contamination from the damaged parts.If the whole trans (clutch and brake packs)has to be removed,disassembled,cleaned and resealed,a planetary set or other hard parts replaced,worn bushings,clutches,seals and bearings replaced and the remainder of the system flushed,plus a couple sets of cleanup filters and 2 fluid changes,you can easily spend $4-$6000+ at a dealer or repair shop.
tom
03-24-2004 04:14:49
 Re: Re: 4020 transmission ques in reply to Mike, 03-21-2004 04:59:31
Mike,
Thank you for your follow-up. I have passed in the information and he really appreciated it.
Regards,
tom
