4630 fwa
Dave
03-20-2004 21:08:19
I am in the market for a 4630. I was just looking for a 2 wheel drive model. But I have came across a real nice one that has the front wheel assist. I was wondering if there are any problems with these? I have heard a few bad things about them but wanted to get some feedback. Thank you.
david val
03-21-2004 09:48:00
 Re: 4630 fwa in reply to Dave, 03-20-2004 21:08:19
the pfwd system uses hydrostatic motors in the wheels with planetary reduction and an electro hydraulic system. there are many things that can go bad with these systems: shorter hydraulic pump and drive life, burst hoses (quite common), contmination due to replacing hoses in not enough clean conditions, dried o rings in valve assembly and brake pistons, bad solenoids (common and expansive) and electical problems (simpler on powershift.
if you have the time and the know-how, you can take apart the wheel assmblies and the control valve. have everything thoroughly cleaned and checked, replace all o ring seals and backup washers and go over the electrical system and you may have a good system for a few years (considering you find no 'surprises').
david
