E-S CD Mag--Info needed
DL61
03-20-2004 16:59:48
Hi guys. I should have payed more attention in class, as I know that this subject has been discussed and cussed many times. Silly me, didn't save the info, now I'm the guy asking the already asked question.
I just got an ES CD mag with a parts tractor. Points are needing to be replaced, but could find no condinser. I'm assuming that there is one somewhere in there, just hated to tear into the mag any further than the top cap. Also noticed that the points and the impulse do not seem to be in time with each other. There never seems to be a time where the impulse trips and the points open and the rotor is in line with the post on the cap. If I'm thinking correctly, these mags have a gear that drives the rotor/points cam. Could this be out of time with the impulse? If so, how do you get it back where it is supposed to be. Thanks ahead for the help. I'll take better notes in class next time.
Clooney
03-21-2004 09:58:04
 Re: E-S CD Mag--Info needed in reply to DL61, 03-20-2004 16:59:48
DL61, the condenser is farther in.. It's behind that big bolted on front cover down on the bottom.. Be careful with that condenser as you can't find them anymore & will have to make your own if you trash it..
~To set the reduction gear timing... first turn the mag rotor shaft until the little timing mark is at the top,, then turn the points cam shaft until the letter L is in the timing window, then slide the front cover on the dowel pins & be sure the timing mark & L stay lined up..
~Be careful working with that mag as the parts are real expensive or very difficult to find..
[email protected]
Bob
03-21-2004 11:54:45
 Re: Re: E-S CD Mag--Info needed in reply to Clooney , 03-21-2004 09:58:04
Clooney,
What is the procedure for setting the position of the breaker points mounting plate, that times the point opening with relation to the position of the iron rotor inside the mag polepieces?
I had an istruction sheet years ago that I've misplaced, and I'll building a CD mag up out of parts.
I know you remove one of the little sidecover plates beneath the magnet, and observe (or measure) the position of the rotor ("armature") through there, but what is the rest of the procedure?
Clooney
03-21-2004 15:23:44
 Re: Re: Re: E-S CD Mag--Info needed in reply to Bob, 03-21-2004 11:54:45
Bob, give me an E-Mail & I will send you the rotor air gap setting procedure..
[email protected]
Earl S.
03-20-2004 19:51:09
I have breakdown if you need it. Can copy
