1010 auxiliary hydraulic reservoir
randy
03-20-2004 16:28:43
I'm trying to help my aunt out with her 1010. When you use both the lift and tilt on the loader, it acts like its out of fluid. I've been told that the size of the reservoir is to small on these tractors and an auxiliary needs to be installed. Deere has a parts listing for one which is no longer available. I can come up wiyh a tank but I'm not sure of the best way to plumb it in. Any help will be greatly appreciated
Mike
03-21-2004 05:12:21
 Re: 1010 auxiliary hydraulic reservoir in reply to randy, 03-20-2004 16:28:43
The pump doesn't have enough capacity to operate both functions efficiently at the same time.The reservoir only adds volume of fluid available for use with a loader with single acting cylinders,or in your case will help keep the fluid cooler,but won't help with the lift/curl.
randy
03-21-2004 05:53:37
 Re: Re: 1010 auxiliary hydraulic reservoir in reply to Mike, 03-21-2004 05:12:21
We had the resevoir filled above the the test cock raised the loader and stopped then curled the bucket thats when everything would get jerky then do nothing. Lower the loader back down and everything is fine. I do agree that the pump is not big enough or has to much wear to effectively run the raise and curl at the same time but should run either by its self.
