Aftermarket 3pt hitch John T, Clooney?
Kevin
03-20-2004 14:27:11
You had mentioned in a earlier post that aftermarket 3pts worked better(for a JD A). I started looking and there is a bunch out there. Do you have(had) real good luck with any particular one? Also is there any little tricks when installing them. Thanks again, Kevin (if there was a charge for all the info from this site I would have to sell my house....)
Clooney
03-21-2004 05:21:23
 Re: Aftermarket 3pt hitch John T, Clooney? in reply to Kevin, 03-20-2004 14:27:11
Kevin, I usually build my own.. My shop made is patterned after the [Saginaw Tractor Parts] hitch.. I have seen a lot of different aftermarket hitches that appear & disappear after a short while but the Saginaw seems to be staying around for quite while now.. A lot places that carry aftermarket 3-point hitches are carrying the Saginaw & just fail to mention that fact in their adds.. If I were personally looking for an aftermarket hitch it would be the Saginaw.. Those Saginaw 3-points have excellent heavy duty sway control, good heavy duty parts, good lifting ability, good adjustability, easy installation, & work quite good..... .. Now for the bad part-- That Saginaw hitch is quite heavy so the shipping isn't cheap.. But some tractor parts supply places are carrying that hitch now [you will still probably pay the shipping but not as much as shipping a single unit, or the shipping is added into the final price].. See link below for the Saginaw hitch.....Once the link is clicked go to products, then John Deere.....
[email protected]
John T
03-20-2004 19:02:55
Kevin, Several years ago I was a used tractor dealer and saw so many brands, sorry I just cant recall any particular ones I liked best. I can tell you my favorite ones had a real solid heavy frame for the top link attachment. Dont forget that you dont want any top link mount to interfere with your ability to switch the power trol couplers over from 3 pt to remote cylinder. I looked for good heavy height adjustment turnbuckles and an easy to use anti sway bar or chain adjusters which lighter units seemed to be lacking. The regular Deere hitches that had that "top link" for their plows that mounted way out on the axles was really a cumbersome set up which the after market hitches with regular top link mounts didnt have and were easier to use.
Sorry I cant give you any brands I liked, but I sure know em when I see em. Top link attachment mounts and anti sway control are sure things to compare among brands.
Let us know what works best for you.
Good Luck n God Bless
John T
