JD 205 Gyramor Rotary Cutter
Rob
03-20-2004 11:08:39
My dad died a couple years ago. He could have done this I'm sure. We have a JD 205 Gyramor Rotary Cutter. I am having a hell of a time getting one of the blades off. I was wondering if anyone knew about removing the bar that holds the blades. That would atleast give me a better angle to work with and allow me to use our impact gun. I haven't been able to find any info on removing that bar and was affraid I wouldn't be able to get it back on. Thanks for any help that is offered.
~rob
Nemo
04-19-2005 06:33:35
 Re: JD 205 Gyramor Rotary Cutter in reply to Rob, 03-20-2004 11:08:39
Mast ball for three-point hitch upper link on JD620
supplied by JD store is 2" diameter, but jaw on
upper link is 1 3/4". What ball will fit? The one they gave me is only 1".
mike marshall
08-03-2004 14:15:59
hi rob mike here I know what your talking about I have a 2o5 gyramor rotary cutter there's
a bolt that is in the middle take it out and
that should let it come off you mit have to use a prybar too get Luse if you need a paper on all
the part's I send you a copy ok! mike
