630 3 point hitch question
Harley in PA
03-19-2004 12:03:38
Hi
I recently became the mechanic for my cousins 630 row crop JD. After fixing and adjusting some things, I think she's ready to do some work. When he first got it, it had no hitch on it. He got an aftermarket hitch from a JD dealer, and acording to my father it wasn't made to pick anything up besides itself. It's since had a hitch put on it from a 530.
It doesn't quite look right. It looks like it'll sway too much. I asked my dad, and he said that it needs different sway blocks. After searching this site, I found that some people say that it'll work, and some say that the elephant ears are different.
Can anybody tell me whats wrong? Also, if you have any pictures of a 630 3 point hitch, I'd love to see them.
Thanks Harley
Harley in PA
03-21-2004 08:14:12
 Re: 630 3 point hitch question in reply to Harley in PA, 03-19-2004 12:03:38
Thanks again!
Harley
MIKE HANLEY
03-20-2004 01:59:01
As to those sway locks. All JD manuels on the 3PT equipment will say where the sway locks are to be set. Some things call for no sway locks and some call for them to be set in the narrow position and some call for them to be set in the wide position.
Clooney
03-19-2004 17:18:44
third party image
Harley, as mark said the links & sway blocks are the same between the 530 & 630.. There are spacers that bolt between the sway blocks & elephant ears to limit lower arm sway.. Even then you might need to add a few extra washers to space them out a little more, especially if the lower arms & ball joints are worn..
[email protected]
Harley in PA
03-19-2004 17:31:28
 Re: Re: 630 3 point hitch question in reply to Clooney , 03-19-2004 17:18:44
Thanks.
From the diagram, it looks as though I'm missing everything from the the arrows out. What are these called the sway blocks or the elephant ears? And how hard are they to get? Can I get them from JD?
Thanks again Harley
Clooney
03-19-2004 17:54:10
 Re: Re: Re: 630 3 point hitch question in reply to Harley in PA, 03-19-2004 17:31:28
Harley, the elephant ears are those big odd looking castings inboard of the red arrows.. The sway blocks [technical name- Sway Locks] are those castings outboard of the red arrows...
~There a quite a few companies either making or selling reproduction sway blocks for those old Deere's..
[email protected]
MIKE HANLEY
03-19-2004 16:23:49
If you want some pictures E-mail me at [email protected]. Have closeups of both the 630 and 730 hitchs. Post below is correct.
Mark
03-19-2004 14:49:00
A 530 hitch is the same as a 630 hitch,same elephant ears,same sway blocks.Even the 730 lift parts are the same,the only difference is the elephant ears.
