Axle width for 30.5 tires on 6030
5020Chris
03-19-2004 09:48:24
Can anyone tell me the minimum width from outside of axle to outside of axle to be able to fit 30.5/32 wheels and tires on my 6030 ? The axles have been cut down a bit in the past so I thought I should check with you guys before getting any wheels. I am currently running 24.5/32s. Any pics would help, thanks.
Brokenwrench
03-20-2004 11:48:08
 Re: Axle width for 30.5 tires on 6030 in reply to 5020Chris, 03-19-2004 09:48:24
If the axles are at least to the outside of your 24.5's you should have plenty enough to use the 30's.you will need about 5" more out on the axle to give you the same tire to fender clearance.Worst case is you will have to use the inside bevel on the rims,(if you get double bevel)
