JD 530 Power Steering Pump removal
Chuck McDonald
03-19-2004 06:49:40
Hi,
A buddy of mine needs to remove the PS pump and wanted to know if it was possible to unbolt the pump from the bracket and slide it enough to get either of the spline couplers apart on the fan shaft either the one by the governor or at the back of the pump. He does not want to remove the radiator. Thanks
Chuck
Chuck McDonald
03-19-2004 23:02:29
 Re: JD 530 Power Steering Pump removal in reply to Chuck McDonald, 03-19-2004 06:49:40
The reason it needs to be removed is one of the two couplings let go and the tractor will run fine, but the ps pump, fan, waterpump, etc will no longer spin. Nothing is seized though because the PS pump and everything else spins freely. Where does this notch go and the sheet metal. A Picture would be REALLY NICE!!! Thanks
Chuck
Clooney
03-20-2004 05:14:58
 Re: Re: JD 530 Power Steering Pump removal in reply to Chuck McDonald, 03-19-2004 23:02:29
third party image
Chuck, you don't notch the sheet metal,, it's the end of the fan shaft tube [in front of the front pump connection flange]. The notch shouldn't hurt as the gasket should still fit ok & work.. [see red cut out on fan tube]..
I haven't ever tried notching the fan tube myself but it sounds like it should work..
[email protected]
John T
03-19-2004 07:56:20
Chuck, Ive been involved in the removal of several, and never was smart enough to remove without radiator removal. HOWEVER, I faintly recall (no WARRANTY LOL) it seems like once we were able to remove the radiator bolts and tilt it forward enough and got it out??? Worth a try maybe. If possible, I suggest you leave the fan shaft spline coupled up front by the governor and remove it there at the pump. Many of those splines are worn bad. In addition to replacement of the seals and smoothing/polishing the shaft's seal areas where needed, we usually replace the half moon woodruff keys that drive the gears, they are often worn. Also if I recall, we had to use 2 separate seals on one end versus a longer one piece unit, I think Clooney has posted those part numbers before.
Let us know the trick if you figure it out!!
Good luck n God Bless
John T
Clooney
03-19-2004 07:21:50
Chuck, maybe!!!
~The book says you can,, I wish the guy that wrote the book would come over & show me how.. I have gotten maybe one out without moving the radiator,, on some I have loosened the radiator lower mounting & gained just enough to pry it out.. On most the radiator has to moved or the governor moved.. There was an interesting post a while ago from a guy [I wish I could remember who] that said he notched the side on the fan tube in front of the front casting [you�ll see what he was talking about when you go to remove the pump] & that gave him just enough clearance to get the pump out..
~One thing I will tell you for sure�BE DARN SURE you place a piece of thin metal or plastic laminate between the front of the pump fan shaft & radiator or you �will� be pulling that radiator�
[email protected]
Howard
03-19-2004 17:31:47
 Re: Re: JD 530 Power Steering Pump removal in reply to Clooney, 03-19-2004 07:21:50
Yes,you can notch the tube to slide the pump shaft sideways. I have removed many, many pumps this way.Have never needed to loosen rad. And yes,a piece of tin between rad and pump.
