? L LA John Deere
Paul
03-18-2004 21:22:30
Whats the difference between a L and LA John Deere? The tractor does not have serial # Tag on it. I do not know how to tell them apart. What years were they made? Any help would be appreciated.
Adam
03-19-2004 17:42:54
 Re: ? L LA John Deere in reply to Paul, 03-18-2004 21:22:30
I thought the easiest way to tell them apart was that the LA had a cast iron center to the rear rim and the L had pressed steel.
Dwayne
03-19-2004 12:00:48
Hercules engine L was produced fron 1938 to 1941 the John Deere engine L was 1942 to 1946. the LA was produced from 1941 to 1946. The LI was produced from 1941 to 1946. try checking the top lip of the Trans where it bolts to the final drive housing, if it is a 1941 or later, it will be stamped either L, LA, LI. this was because all three were geared diffrent, so they were stamped so they wouldn't put the wrong trans in the wrong tractor. if it has no stamp, it is a 1940 or earlier L
Paul
03-20-2004 10:53:57
 Re: Re: ? L LA John Deere in reply to Dwayne, 03-19-2004 12:00:48
Thanks for all your help. I appreciate it
Dwayne
03-20-2004 16:05:35
 Re: Re: Re: ? L LA John Deere in reply to Paul, 03-20-2004 10:53:57
Any Time. What did you find?
Aaron
03-19-2004 07:15:04
Some other differences, The LA's had 24 in rear rims and the L's had 22. Most of the LA's had a solid steel frame while the L's had a hollow tube frame. The early LA's did have a hollow tube frame but it was thicker then the L's. I can't remember the measurements but if someone else dont post them I will measure tonight.
Good Luck
Aaron
jdemaris
03-19-2004 09:35:41
 Re: Re: ? L LA John Deere in reply to Aaron, 03-19-2004 07:15:04
On an LI that I had, it had a double-wall tube frame. As I recall, it was an industrial version of the tractor.
jdemaris
03-19-2004 05:04:07
Engine is bigger in the LA but I don't have a database with the exact numbers in it. L used a Hercules two cylinder with a 3 1/4" bore, LA used same with a 3 1/2" bore.
Dwayne
03-19-2004 11:51:38
 Re: Re: ? L LA John Deere in reply to jdemaris, 03-19-2004 05:04:07
the LA never used a Hercules engine, they were all JD's own version. the Herc had a detachable bellhousing the Deere didn't. the JD engine had a place for a starter and the herc didn't. the thickness of the frame on a hollow tube LA was 7/8" thick wall.
