GMAN I think i went to far
Kim GM
03-18-2004 20:32:25
Im rebuilding my 47 GM and a guy in town pulls G's so i thought id inlist his help.Well i went .125 over m/w's and welded one spark plug relef on each piston.Then he shaved about .200 the off the block and now he's talking about shaving the head to the eyebrow. I don't think theres any chance for a stock head gasket to last . it was going to be a light puller/plowdays tractor.Should i just buy a new head or thick copper head gasket.Any thoughts?? Thanks Kim GM
DON
03-19-2004 14:07:21
 Re: GMAN I think i went to far in reply to Kim GM, 03-18-2004 20:32:25
.030 IS ABT ONE COMPRESSION RATIO. I WOULDNT GO ANY FARTHER IF YOU WANT IT TO HOLD TOGETHER.JUST MY 2 CENTS.DON
buickanddeere
03-19-2004 08:06:57
If it isn't a early flat head it should hold,the metal is getting thin with all the cutting. Custom shortened push rods will be required. After getitng to the 7-9 to 1 compression range more compression gains little extra power. With those pistons leave the block alone. And spend time on just increasing airflow through the head instead.
thanks
03-19-2004 16:49:56
 Re: Re: GMAN I think i went to far in reply to buickanddeere , 03-19-2004 08:06:57
thanks
