430 garden tractor
Bill
03-18-2004 16:45:40
I am thinking of buying a 430. The shifter is really stiff but does work and the tractor only has 620 hours on it and is in excellent shape. Is this a easy fix?
Bguy
03-18-2004 19:18:17
 Re: 430 garden tractor in reply to Bill, 03-18-2004 16:45:40
I had one of those for 18.5 years and it was a great mower. The hi-low range shifter was pretty stiff but I probably never changed mine a half dozen times while I had it. Other than changeing the filters and fluids I never did anything to mine. I really liked mine because it had a real low center of gravity and would go up and around hills and banks like a billy goat. I filled the tires with fluid which helped alot. I finally traded mine off last year for a JD X595 with the 4x4 and a few more horses, if it's 2/3 as good as the 430 was I can't complain.
bob
03-18-2004 19:01:45
got one of these and I never shift out of low range- for some reason its a real bear to change ranges- always was since new. How much is the 430? Anything less than 5 grand you cant go wrong- bob
Bill
03-18-2004 19:35:26
 Re: Re: 430 garden tractor in reply to bob, 03-18-2004 19:01:45
3800$ and it is in super shape. I just wanted to make sure this was an easy adjustment before I get it. Seems a great deal and twice the tractor as the newer versions.
