JD 11/2 model E
Mark
03-18-2004 15:40:22
How do you time the crank to the cam gear? I see the mark on the cam gear but not on the crank. Is there a starting point on installing the main bearing shims? As in using thick, medium or thin.How long are the skids? Are they longer if mounted on trucks? Thanks...
Mark
03-19-2004 08:45:19
 Re: JD 11/2 model E in reply to Mark, 03-18-2004 15:40:22
Thanks for the info. I bought this engine completely torn apart. It is surprising how many parts are still available from JD. Plus the many different aftermarket sources. Mark..
Duane Larson
03-18-2004 19:19:59
Mark,
There are two marks on the cam gear, and one on the crank gear. Best as I recall the crank gear is marked close to the crank throw, so is a bit tricky to see - try looking hard in that vicinity for a dot. When (if) you find it, it should line up with one dot on the cam gear such that the other cam gear dot is at the top of the cam gear, and should be matched up with the dot on the magneto drive gear for proper gear timing.
Ron in CO
03-18-2004 17:20:47
The Skid for the 1 1/2 HP E measures 33" long by 2 5/8" wide by 3 3/8" deep. I assume the dimensions are the same with or without truck.
If you already have a truck and need mounting hole dinmensions, post back. If you are going to buy a repro truck, the mounting dimensions will most likely be included with the truck.
Clooney
03-18-2004 16:41:40
Mark, there should be marks on both the cam gear & one on the crank gear.. I have found a few type E crank gears that were real hard to see or even non existent from rust, or who knows.. If you haven't totally disturbed the rocker arm adjustment or can get it back close to where it was you can use the Exhaust Close mark on the flywheel to set the cam timing [that mark should line up close to even with the exhaust push rod as the exhaust valve closes].. Or if the engine isn't together you can watch the cam follower & when the cam just drops to it's lowest point the Exhaust Close should be close to pointing straight forward [this method works best if you have done a few before]..
On the main bearing shims?... I always start with what was in there to begin with, then work down from there until the crank has a little drag, then add a little back.
On the skid question? I can't answer that right off but if you don't get a good answer here give me an E-Mail & will try to measure one of mine.. They're all tucked away for the winter so I will have to wade my way to the rear of my back barn to do that so hopefully someone has theirs a little handier..
You have one more hurtle yet.. That will be the mag timing? Those Deere low tension mags a REAL CRITICAL on being perfectly timed or you will get absolutely no spark.. when you're ready to install the mag post back or E-Mail for proper instruction on timing that little devil..
[email protected]
