Mark T, you ask if going to an 8 volt battery would be a good idea, in my opinion it would would work (for one thing you gotta get the Voltage Regulator set up), but I think its a much better idea to either a) repair the 6 volt original system using a good heavy duty high amp hour or CCA rated battery or else b) go ahead and convert up to a full 12 volt for a more standard operation. How old is your battery and how big and have you had it load tested?? What size cables you have???? Maybe a new heavy duty battery and some bigger cables and better connections is all you really need. Maybe a better solid frame member ground closer to the starter will help. Any idea what shape your starter is in??? When cranking if you place a voltmeter on the battery or have the lights on, does the voltage drop and lights dim considerably???? If so, the starter may just need minor attention like new brushes or bushings. If you stay at 6, do as Mark mentioned and check the connections and grounds etc., and on 6 volt systems, I recommend the use of 00 Gauge battery and starter and ground cables PLUS the heaviest amp hour or CCA rated battery you can fit into its mountign enclosure. On the 6 volt, you gotta have a heavy battery plus good heavy cables and solid grounds plus a good starter and switch or solenoid. If youre gonna convert, I would step up to a full 12 volt versus an 8 volt system, which isnt standard, requires the generator and VR to work at 8 volts, may have light bulb problems, and Im unsure as to the cost ratigns and easy availability of the battery. Sooooo ooooo check the battery (size and load test) and cable sizes (00 Gauge) and all connections and see what the voltage is doing when cranking (volts drop and lights dim??) and then peform any minor starter repairs like brushes or bushings (cuz youre still gonna use it regardless of any 8 or 12 v conversions), check the switch or solenoid, and then make your decision. Is there a good old fashioned gen repair shop nearby to set up the VR if you go with 8 volts???? Once you decide, post back or e mail me at [email protected] with any conversion questions etc. Let us know what you decide, there are differing opinions on the best way to go, mine are simply repair the 6 including the recommendations above or go to a 12 versus an 8. Good Luck n God Bless John T
