Improving the seat on a 4020
Toby
03-17-2004 19:49:25
I recently purchased a 4020 to cut hay with. The problem is the how rough this old girl is going to ride at 6 miles per hour. Is there an after market suspension that I could use or how do I go about rebuilding what I have. My 4020 is not for show but to use if you need to know.
Thanks
toby
Jake
03-19-2004 21:27:55
 Re: Improving the seat on a 4020 in reply to Toby, 03-17-2004 19:49:25
Quite likely it has worn and broken parts and just needs to be rebuilt. I did one on a 3010 years ago but do not remember today the details. This one was worn so bad that the bushings wore completely through and egged the holes the bushings fit into. There is also a cable in there somewhere that can break. I don't remember what it had for a suspension spring. You will just have to get in there and find out what it needs.
Dave in Dallas
03-18-2004 14:53:55
Check the weight setting on the seat. It might be set for a heavyweight person. Dave
JD68
03-18-2004 04:02:51
Tobey you can rebulid all the suspension in the seat and get the spring counterbalance working corretly. I did my seat last winter and it's better then new (or at least as good) wasn't cheap I put about $50.00 in parts and there were no major parts just bushings,special nuts etc.
