P55, As far a I know there isn't anything special about the early 70 gasoline manifold.. There is a difference in the all-fuel manifolds though.. ~Seeing as the 70 used bolts instead of the earlier studs it is pretty straight forward to replace that manifold.. Just pull the carb intake pipe, carb, exhaust pipe, then remove the attaching bolts [more on that later] then slide the manifold out.. That manifold is a 2 piece with an adjustable heat valve & in a lot of cases the heat valve will be stuck or eroded so a new heat valve would also be a good idea [those heat valves usually don�t come with the manifold].. ~You might want to look closely at the intake portion as those tend to crack or get holes in them & that will cause all kinds of runability problems or poor idling.. You might also need a new retaining strap that holds the heat valve up as those rust pretty thin & bend easily.. Replace all the gaskets between the manifold & head & manifold sections.. I also use new bolts to hold the manifold on.. ~If the cylinder head ports are pitted or eroded you might need to clean them up but if you file on them remember the heights must remain the same between the ports� If the port surfaces are not too bad you can use a good hi-temp exhaust sealer on the gaskets when re-installing the new manifold. ~OK, now on those bolts?.. Use a little penetrating oil & possibly some heat on the bolt heads.. Then try to remove them.. Problem is, the heat & penetrating oil seldom gets to the bottom of the bolts where they enter the head.. Try your best to get those bolts loose but don�t break them off.. IF it feels like those bolts are going to snap off [you know the feeling, kind of a slow mushy turning with no loosening] STOP & just drill or use a torch & pop the bolt heads off.. Then use more heat & penetrating oil between the bolt & manifold.. Once you get the manifold loose on the bolt shanks just pry the manifold up as far as possible, then stuff rags or paper towels in the ports under the manifold, then use a Saws-all to cut the bolts off at the bottom of the lifted manifold.. Once the manifold is pulled out that leaves enough bolt sticking up to use heat on the bolts & head & still get a pair of vise grips on the cut off bolt stubs.. A little extra time here can save you a lot of drilling later so don�t rush the process.. ~I don�t know what to tell about a place to buy the manifold, I have tried quite a few places & sometimes the castings are real good & the next one will be kind of shabby.. Even some of Deere�s manifolds are cast by the aftermarket now so you never know what you will get.. I try to buy mine at the national shows as you can look over what�s there & pick a good looking casting.. [email protected]
