3010 ALTERNATOR
Skybow
03-17-2004 13:16:27
Clooney or John T
Last winter I replaced my generator/voltage regulator with a GM alternator. All seems well but I have to rev it up to 1600-1900 PRM's to get the voltmeter needle to show 14-15 volts. When I throttle back the needle stays at 14-15 volts. Is this because there is a level of output that I have to exceed in order for the alternator to charge the battery. Once that threshold is crossed does it continue to charge even though the RPM's are lower than the 1600-1900 range? Thanks
Hey Clooney and John T
03-19-2004 21:31:49
 Re: 3010 ALTERNATOR in reply to Skybow, 03-17-2004 13:16:27
On those one-wire regulators... You can connect a switched power source to the terminal the same as you do on the 3-wire units and it will start charging at low RPM or idle speed the same as the 3-wire units. The second terminal that you connect to B+ power on the 3-wire units is already internally connected on the one-wire unit.
Hope this helps.
-Jake-
Skybow
03-17-2004 18:52:28
Thanks guys, I'll be ut of town working for about 4 days. I'll check this out some more and let you know what I find next week. Thanks for all the great info.
Clooney
03-17-2004 16:05:04
Skybow,
A couple of things come to mind on your problem..
1)- If you have a conventional GM 3 wire Delco 10-SI alternator your ignition power wire running to the alternator's #1 regulator terminal is either broken, developed too much resistance, or was never hooked up correctly to begin with.. If that circuit is there & working then you might have a failed internal regulator or a failed diode trio... If your #1 terminal ign power wire is there & has 12 volts on it you probably need alternator work.. If that #1 terminal power wire is there but doesn't have a 10 ohm resistor [or light] in it you might have failed a diode trio if you have ever jumped that tractor & hooked the jumpers up with the ignition switch left on [easy to do].. If that #1 terminal wire has a higher resistance than around 10 ohms it will also delay the cut-in RPM.. There were some postings a while ago stating to use more than 10 ohms in the ignition initiation circuit & that can lead to a high cut-in RPM on a Delco 10-SI alternator.. If a generator light was used in the alternator's initiation circuit & that light is burnt out that could be your problem..
2)- If you do have 1 wire Delco 10-SI alternator then that high initiation RPM is probably normal [if you didn't buy a low initiation RPM alternator]..
3)- One place to start, is to determine IF your alternator is a one wire [will probably have black plastic cover over the regulator terminals] or 3 wire [won't operate without a wire on the back running from the [BAT] post to the #2 regulator terminal].. If you have a one wire alternator you are either stuck with the high cut-in RPM or will have to buy & install a low RPM cut-in internal regulator..
4)- If you do have a 3 wire Delco alternator, turn the ignition switch on & see if you have power to the regulator's #1 terminal wire [should be 12 volts with the connector pulled off the regulator & slightly lower with the connector hooked up].. Measure for power on the connector terminal & not the regulator terminal .. If you don't have a wire on the regulator's #1 terminal that's probably your problem [let me know that & I will tell you how to wire that #1 terminal]... If you don't have power to that #1 terminal you can try a test.... To do the test just make a short jumper wire up & attach that from the [BAT] post on the back of the alternator to the regulator's #1 terminal, then start the tractor & see if it starts charging sooner.. If it does, you have a problem with your ignition power wire to the #1 regulator terminal.. If that jumper helps then let me know & we will come up with a repair for you..
__If the above sounds like Greek [probably does] here is a shortcut..... ..... ...
Look at the alternator.. If it has a black plastic cover over the internal regulator you are probably stuck with that high RPM cut-in..
If no plastic cover, see if there is a wire running to the #1 terminal of the internal regulator [it's marked on the alternator case next to the terminal]-- If no wire post back or E-Mail me for a working repair...
If there isn't a wire on the #1 terminal try the jumper test above [if that helps post back or E-mail for a working repair] .....
If you have a wire on the #1 terminal & it has power to it with the ignition switch turned on you probably have an alternator problem [If you want to repair that alternator give me an E-Mail & I will talk you through the test & repair of the alternator, it's not real complicated]..
[email protected]
John T
03-17-2004 15:48:11
Sky, alot depends on the alternator, if its a "one wire" self excitation type (those typically require higher RPM's) or,,,,, ,,,,, if its a 3 wire like the GM 10 SI and you have it "properly externally excited" like via an idiot light or some other sort of switch/circuit feeding its lil No. 1 side terminal,,,,, ,,,or maybe you have a 10 SI but arent externally exciting it as you should.
You have a gas or diesel and what alternator and what excitation set up (if any) you currently have now????? ????? To externally excite those GM 10 SI, you need a circuit thats hot when youre up n runnign and wanna charge, that has about 10 ohms total resitance and maybe a diode (if a gas and she back feeds) in series.
Regardless, a 12.6 volt battery should still charge decent (depends on the battery type, alternator and regulation circuit) even if youre at 14 or 14.5 volts.
To answer your questions, (1) YES you have to exceed a voltage higher than the battery to ever charge it and that depends on the alternators RPM and how its regulator circuit works. (2) YES regardless of the exact RPM, if the alternators output voltage still remains higher enough over the batterys, current will flow into the battery i.e. charge it.
If you have a voltmeter and it is half way accurate I dont think you have much of any alternator problem if it goes to 14 and 14.5 or so at high RPM's. If it only went to 13 max, then you may have a problem and may not keep the battery charged. On some auto batterys and circuits thay need a lil more voltage, but I think 14 (dependign on battery) ought to keep you going. I think clooney has access to GM alternator output curves??? I dont have access to data or specs here, but if a charging system raises the battery to 14 volts its puttign energy INTO the battery (even if not 14.5) you ought to keep charged.
Also, is the belt good and tight and not slipping and are the drive and alternator pulley sizes right to turn the unit at sufficient RPM? As you know, a larger drive pulley or smaller alternator pulley (assuming no belt slippage) can affect the RPM and alternator output.
Good luck n God Bless
John T
