4430 valve clearances
charles
03-17-2004 00:31:55
My JD supplier kindly lent me their engine turning tool but I found that it did not seem to fit ; the casting(part of the block) for the tacho drive prevented the tool from lining up and going into the hole in the flywheel casing. I did not remove the cover from the tacho casting because I did not think it would help and the manual did not mention that I needed to. I could have cut a length from the tool and re-welded the hex head but it was not my tool.JD insist that it must fit. It is a late model 4430 eg steering valve under bonnet (You would call it a hood!) Manheim built , could the UK tractor be different ? Are there different types of tool? Many thanks in advance
david val
03-17-2004 10:33:29
 Re: 4430 valve clearances in reply to charles, 03-17-2004 00:31:55
i never encountered any problem with the rotation tool at any 400 or 500 series engine. mayby the tool is a makeshift or 'improved'. you should though, disconnect the breather hose and pull down the lower tube (sometimes they stick).
i used to turn engine for valve adjustment by pushing on the belts with one hand, rotating the fan (carefully!!!) with the other while watching rockers for end of exhaust overlaping.
G-MAN
03-17-2004 07:37:25
I don't much care for the spring-loaded engine rotation tool myself. I actually use one that's made for Cummins "B" series engines. Fits good in the hole and works like a charm. If you can't use the rotating tool, you might pull the bottom frame plate off and use a pipe wrench on the hyraulic pump drive. You can use the injection pump timing marks to set TDC compression for #1 and then mark the balancer. Pull the little plug out of the front housing right by the oil fill. Look in there and you can see the pump timing marks. When they're lined up, your at TDC compression for #1 cylinder. It's not strictly necessary to set the engine at the two TDCs to adjust valves. You can use split-overlap/rockover and adjust the valves one cylinder at a time.
