630 hood rubber gromets
jacksun
03-16-2004 21:29:51
my 630 hood is missing most of the rubber gromets does anyone have these or know how to make them?
MIKE HANLEY
03-16-2004 23:03:00
 Re: 630 hood rubber gromets in reply to jacksun, 03-16-2004 21:29:51
They are still availible from JD for about 50 cents each. The parts book also call for a spacer. Forget the spacers and drop a 3/8" nut into the center of the rubbers On the bigger rubbers that go under the front of the long hood where it attachs to the radiator, use a washer both on top and bottom of the rubber and no spacer used here.
The 4 springs and the 4 steel spacers that go under the nose cone and still availiable.
robert bacon
03-31-2004 08:24:17
 Re: Re: 630 hood rubber gromets in reply to MIKE HANLEY, 03-16-2004 23:03:00
I am a private farmer, doing minor repairs on my tractor hood.
Please e-mail me back, I have an 1972 Ford 3000 and 1979 white 2-60. They both need hood gromets.
Mike M
03-17-2004 10:06:41
I think the big rubbers that mount to the top of the radiator also use a spacer that goes thru the rubbers and down into the hole on the brackets attached to the hood and rest on the top radiator tank.
MIKE HANLEY
03-17-2004 03:21:25
PS: Pull the lower dash and there are two bolts that take a 5/8" wrench that hold the cast cowling to the top of the shifter casting. Loosen those two bolts and then line up the hood from the nose cone to the long hood and then long hood to the cowling. That way there will be no gaps at the line at the nose cone/long hood and at the long hood to the cowling.
john reichert
03-17-2004 05:12:13
 Re: Re: Re: 630 hood rubber gromets in reply to MIKE HANLEY, 03-17-2004 03:21:25
thanks mike you guys are great source of info for us rookies.
