G reverse high or low
Ken C.
03-16-2004 20:18:36
I just put together the trans on my 52 G, and the reverse seems to work in high range and low range. I have never driven a G before and my A does not have a high range reverse, does the G have two reverses. Just wondering before i put the top on. Thanks Ken.
G-MAN
03-17-2004 07:39:05
 Re: G reverse high or low in reply to Ken C., 03-16-2004 20:18:36
Clooney is correct. The "G" never had the high-reverse lockout.
Clooney
03-17-2004 03:46:46
Ken, the early A's had a pin on the reverse shifter to manually push the hi-lo shifter into low range when reverse was engaged. I believe the later 70's also had a similar set up to force the hi-lo shifter into lo range.. I don't think the G ever had that set-up. It's no big deal if you don't as a lot of those reverse pins were removed from the A's & later 70's so reverse could be engaged with the trans in either hi or low range.. It just makes it easier to shift into reverse & not have to put the hi-lo lever back into hi range again.. I usually pull those pins from my transmissions.. For any serious reverse work it requires the hi-lo shifter to manually be put in lo range but for a quick reverse to just back up a little the hi range reverse will work fine..
[email protected]
buickanddeere
03-16-2004 20:22:50
While not directly related, that G can be slowed down in all gears. The 1st reduction gear set from a 70 diesel should bolt right in. Both of our 70's can be shifted into "Race" low or high range.
JohnDeere2Cylinder
03-17-2004 17:20:54
 Re: Re: G reverse high or low in reply to buickanddeere, 03-16-2004 20:22:50
I am really interested in slowing down my 1951 JD "G" for pulling. Can you give me some details about the 1st reduction gear set of a '70 Diesel?
Thanks,
Steve
[email protected]
buickanddeere
03-17-2004 21:03:39
 Re: Re: Re: G reverse high or low in reply to JohnDeere2Cylinder, 03-17-2004 17:20:54
The diesel runs at 1125rpm with the same ground speed as the spark ignition G/70 at 975 rpm. The 1st reduction gear set has a higher ratio in the diesel. It should bolt in. Mike Alward ( spelling and my lousy memory) figured the fix out long before I did.
Ken C.
03-16-2004 20:33:53
I guess it's together right then, the 70 gears sound like a good idea, but a 70 diesel would probably be hard to find, i have never seen one down here in my neck of the woods, thanks again,Ken.
