1937 a carb help dltx 18
Mike
03-16-2004 20:12:20
I am new to john deeres I bought the drill bits from roberts to clean the idle passages and set the float but i cant get it to run good at idle I have the power set one turn out and the idle about the same maybe 1/2 more set it at wide open throttle like it says to it runs good thier but when you set it back it is way rich. When i went into the carb i found a spring and ball bearing behind the big nut is this factory i have not seen this befor so i left it out should i put it back starts good but i need help. Thanks Mike
Clooney
03-17-2004 07:33:24
 Re: 1937 a carb help dltx 18 in reply to Mike, 03-16-2004 20:12:20
Mike, usually when you have a carb idle problem they go lean at idle & not rich..
~It sounds like you have your load needle set at about 1 turn out from seated & the idle needle maybe around 1-1/2 turns out from seated. That should be pretty close for it to run ok.. If it still goes rich at idle you might have other problems..
~Is there a chance you drilled in too far with those Roberts drill bits or drilled something other than the main passages & fuel holes. If you managed to drill into an idle transfer hole or managed to enlarge the bowl vent passage you could have big problems..
~How slow are you trying to idle it? If you are trying to idle it too slow they do go a little rich at real low RPM�s..
~If you are pretty sure you cleaned the carb properly then you should look closely at the throttle plate.. That throttle plate MUST fit the throttle bore properly & not have gaps on the ends [worn throttle plate ends are a big problem on the older 2-cylinder Deere�s].. You also want to make sure the throttle shaft bushings aren�t worn [loose throttle shaft bushings are another big issue on the old DLTX carbs].
~You might also want to check the idle & load needles for wear rings on the stems & make sure the needle ends aren�t bent or broken off..
~Another thing to try is using some pipe sealer on the load & idle needle threads [an air leak at the tops of the needles can allow air to be pulled in there & cause metering problems]..
~You want to be sure your float level is set correctly & the float isn�t bent, crushed or partially full of fuel.. I usually just set the float top parallel with the top of the float bowl & call that good.
~On that spring & ball issue.. There has to be a spring under the load nozzle to hold it up into the nozzle bore but that ball is not required.. Maybe the spring is the incorrect one & the ball was used to make it work.. That spring is kind of conical shaped.. You might be able to just stretch the spring you have & make it work [all it has to do is hold the nozzle up into the bore]..
~OK, now lets look at the ignition system.. If you have carbon core automotive resistor plug wires they have to go.. That ignition system won�t operate correctly unless the plug wires are solid metal core.. You should probably install new spark plugs also as partially fouled spark plugs are a leading cause of poor running & poor idle.. When you install new plugs try opening the plug gap a little to about .035�-.040� [that alone can help a poor idle]..
~Make sure your mag snaps as the L/H impulse on the flywheel lines up with the case mark [at 3-o�clock behind & even in height with center of the flywheel.. If your ignition is running late at low RPM�s it will go rich..
~Make sure your gasoline is fresh & not old & stale [that will give a pretty bad idle]..
~You might also want to do a do compression test with the choke & throttle wide open [low compression will effect the carb settings low speed runability]
~There is plenty more to try but this is a good start so try some of the above then post back [or E-Mail] if anything helps or hurts & if nothing found we�ll give you more things to look at..
[email protected]
John T
03-17-2004 06:46:51
Mike, on that poor idle problem, here are a few thoughts:
PRELIMINARY, See if the air cleaner bowl is clean and water free and you have fresh clean water free gas. Also, you gotta have a well tuned engine and ignition with a good hot blue spark and good plugs for a good idling engine. Checked or changed plugs and/or points lately ???
Post back any ignition problems or questions.
CARB AND FUEL RELATED POOR IDLE PROBLEMS
1) The usual rough in settings are about 1 3/4 to 2 out for the idle needle and 3/4 to 1 out for the load. Do those adjustments seem to help???? Will she idle okay if choked some?????
2) You say you drilled out the idle passages, did you drill all ALLLLL of them and did you use the proper sized No. 40 and 53 bits in the right holes ONLY??? ALSO, there are smaller passages not big enough for those bits I use steel guitar strings to clean out. They alllll l should be clean for a good slow even idle.
3) Were your throttle shaft bushings NOT worn out with excess play or slop??? If they are worn, vacuum sucks air in past them leaning the mixture causign poor idle. See how tight your throtle shaft is??? If real sloppy, she sucks air in past them.
4) Got any vacuum leaks??? That leans the mixture causign poor idle. At idle spray WD 40 or Carb Cleaner or an unlit propane torch around the carb to manifold union and the manifold base and the carb, ESPECIALLY THE THROTTLE SHAFT BUSHINGS and if she speeds up or smooths out, you have found a vacuum leak problem.
5) Was your throttle plate tight on its shaft and nice n round n smooth and does it mate up well with the carbs bore???
6) Does it idle up n down and hunt and surge some for RPM??? If so, is the adjustable idle stop screw bumping up against the stop spring slightly??? If you remove the governor shaft from the carbs top and manually control idle, will it idle nice n slow n smooth that way??? (If so, maybe a governor or adjustment problem)
On the inside bowl center bottom, that spring was designed to hold the center brass vertical nozzle up in place. Its supposed to be there. Maybe the ball bearing you found was a spacer to take up a worn out springs tension????? The spring is factory, not any big ball bearign there, I would just use a new spring. It not beign there shouldnt cause the idle problem you described, however.
Did you extract the center nozzle and clean it and all its lil side holes out??? if they are clogged, it can cause a load problem.
Theres possibly more, but check these thigns out then post back or e mail [email protected] with any questions.
Good Luck n God Bless ya Mike
John T Nordhoff
