51 A trans
Larry806
03-16-2004 18:30:58
The 4 & 6yh gear cover was leaking When I took it off the bottom gear needs replacing. I have a parts tractor but can't get the gear off of it.The gear on the good tractor had bolt holes to pull it with The parts tractor doesn't Thank you for any help
Clooney
03-17-2004 03:51:59
 Re: 51 A trans in reply to Larry806, 03-16-2004 18:30:58
Larry, you are going to need a gear puller to pull that gear off. A 3 jaw works better than a 2 jaw puller.. Be careful if that gear is on tight so you don't pull on only the gear teeth but try to get the puller jaws to sit deeper on the gear hub ..
[email protected]
