Good Evening David, Im pretty much in agreement with my friends below, I rebuilt my 38 B Governor and Ive done worse jobs before. 1) First, remove the governor throttle rod shaft from the carb and see if you can manually get her to run and not surge however. If she still surges, then it may well be a governor problem. You know, a clogegd idle circuit or passage in the carb can cause up and down RPM and uneveness and what seems like governor hunting and/or what some may call surging..... Are you sure the carb is good in the idle RPM range????? ????? 2) Did you set the rod linkage so when the carb and hand throttle are wide open the rod is aobut 1/2 hole short of dropping into the carb??? 3) Is the linkage including where the rod drops into the carb free and no binds and no cotter keys jamming up preventign any smooth movement from idle to wide open ???? 4) If she will manually idle smooth but not via the governor action and you already tried all the above, it may then need governor attention. 5) If you remove it, dont forget to remove the lower oil supply line up under the governor accesible from the top crankcase cover. 6) Often, the fan shaft bevel gears get worn and very sharp and cause whine plus excess free rotational end play in the fan shaft. Whats your fan shaft end play like now????? ? If you replace those gears, get a matched set, either used off the same tractors gears (fan and governor) or a new matched set. 7) The end bearings can be worn causing a roughness and noise. 8) The pins that go through the weights or the weights there can be worn causing delayed action and/or sluggish operation and some noise or roughness. I failed to replace my pins but wish now I had. 9) We used a heavy arbor press to press on the gears and they have to be chucked up tight close and proper and it really took a bunch of force to move them I recall, made me PUCKER lol Try the easy simple things first like carb or carb idle needle adkjustments,,,,, then look at the linkage adjustment,,,,, , then be sure of no bindign or cotter key problems in any connections,,,,, ,then try the manual throttle to see if she will run smooth,,,,, then maybe finally suspect the governor and see how much fan shaft backlash you have now (sign of worn bevel gears and/or need adjusting) Its possible to adjust the governor bevel gears to one extent (side to side) by addign or removing shim gaskets under the end bearing cap you know and adjusting the fore/aft by the same under the fan shaft to case mount. Thats how you set the bevel gears heel/toe and mesh and backlash if you use a new or used set, using more or less gaskets at those 2 places. If this dont work to be fair and spread the work around, this time I volunteer Frank to come fix it lol Good Luck n God Bless ya David John T
