3rd attempt on questions
Brian
03-16-2004 16:48:45
My '51 B has a Behlen power steering unit. I do not know what type of oil it has in it. How do I tell if it is hydraulic or just motor oil?
What will happen if I mix hydraulic oil and motor oil?
If motor oil, what wt should I use?
Thanks!
Larry806
03-16-2004 18:24:29
 Re: 3rd attempt on questions in reply to Brian, 03-16-2004 16:48:45
Most of the Behlen units I've seen use a automotive pump and use automatic trans fluid
Clooney
03-16-2004 18:04:41
Brain, I must apologize for not answering your E-mail sooner.. I'm running quite a ways behind on my E-Mails & yours is down the list a ways yet.. One of these days I will catch up.. (I try to answer the E-Mails related to my responses on tractor boards first, then get to the general ones as I can)
~Now to try to answer your question.. It isn't recommended to mix hydraulic oil & motor oil but probably won't really hurt anything if you do.. I would imagine your add on power steering originally had motor oil in it as that was used in most hydraulics back then but I can't answer that for sure.. I guess if it were me I would drain the system [it probably needs it anyhow] then use Deere Hy-Guard to refill it with.. That way at least you have a consistent oil & that Deere Hy-Guard will work in about any hydraulic system..
~The best way to tell motor oil from hydraulic oil is to sniff it but that won't work on your well used old oil. Both motor oil or hydraulic oil will look about the same after years of use..
~I looked & I do have some older information on the Bethlen steering unit but no where does it mention the type of fluid to be used..
~Sorry, I just don't have any information on the oil to be used in that Bethlen unit.. I had one one a "B" a few years ago & used Hy-Guard in it with good results..
[email protected]
Bob
03-16-2004 17:53:12
First, I would search the archives on this board and the Farmall board for "Behlen", and see what has been posted in the past. If no help there, I would drain the system and refill with Hygard, or other universal tractor fuild. For the small amount of oil involved you could run it enough to warm it up, and then change the oil again.
You have to remember that oils have been improved a lot since those units were made, and back then hydraulic oil was a rare and new item, so engine oil was recommended. I think, generally that would refer to NON-DETERGENT engine oil, a rare commodity, indeed, nowadays. In most cases, hydraulic oil tends to foam less than engine oil that's used in a hydraulic system.
mike
03-16-2004 17:53:12
10wt motor oil will work,it will mix OK
