'59 730 pony start to 12 volt
J.R. Dobyns
03-16-2004 16:16:53
I would like to know if there is a kit or a list of parts I can get to change the pony engine from 6 to 12 volts. I have to rewire the tractor so I will install 12 volt lights. I think an alternator from a chevrolet will work. Does anyone have any suggestions on how to change the whole elec system from 6 volt to 12 volt?
buickanddeere
03-16-2004 16:33:40
 Re: '59 730 pony start to 12 volt in reply to J.R. Dobyns, 03-16-2004 16:16:53
A solid state regulator on each lead to each the starting engine coil to maintain 4.5 to 5.0V when running. A bypass starting circuit won't be required in this situation. An extra resistor in the coil supply circuit(s) doesn't work as it's a two coil system. Sometimes none,one or both coils are energized. Our 6V lights on the 70D were dim and a 12V conversion was considered. Turns out solving the cause rather than treating the symptom worked. Ground wire returns were added from the lights back to the battery ground at the back. The proper 6V lamps were found/installed and the inside of the lamp reflectors were cleaned up. The voltage regulator was found way low at 6.5V and was cranked to 7.2V measured at the battery at fast idle and lights off. A 12V conversion will skew the fuel gauge reading even if a dropping resistor is used. Another solid state 6.0V regulator in the supply will be required.
BMA
03-17-2004 11:37:50
 Re: Re: '59 730 pony start to 12 volt in reply to buickanddeere, 03-16-2004 16:33:40
I've been thinking along these lines too, maybe i'm missing sumthing but why use 3 solid state reg's, would it not be simlper to use one reg to feed both coils and the fuel gauge.
i also thought do i set the reg at 6 volt and retain the orginal resistor or set to some lower voltage? (havent worked out what yet) and feed the distruburtor directly, this way would need a seprate reg for fuel gauge.
has anyone tryed either of these methods ?
Barry.
Clooney
03-17-2004 15:09:06
 Re: Re: Re: '59 730 pony start to 12 volt in reply to BMA, 03-17-2004 11:37:50
BMA, those 6 volt pony tractors don't take kindly to a 12 volt change over.. It can be done but will take a lot of work..
~Those pony coils won't take much over 5 volts for long & those pony coils are just too expensive to experiment on..
~You also have to consider the fuel gage as that diesel doesn't have an ignition switch that stays powered up while the engine is running.. Your original gage is powered up from the original generator..
~You have some options & one is those is the LM type IC voltage regulators that Glen talked about.. Those just aren't large enough to power the entire 6 volt part of this system.. Even if you could find one large enough those voltage regulators can't be left powered all the time due to parasitic drain so one would have to shut down with the ignition switch [for pony operation] & another would have to come on line from the alternator to power the fuel gage.. If you tried to power from the alternator you wouldn't have power to the pony ignition until the engine was started [that won't work] & if you tried to just power form the ign switch it would shut down when the pony was shut down..
~Another option & probably the way I would go is to use a 12 to 6 volt voltage reducer from J.R. Brillman [they're about $6.00 each] in conjunction with the stock ign switch pony coil resistor.. That would cover the pony ignition & possibly a second one for the fuel gage.. That way the ignition switch & lights could operate at 12 volts & the pony ignition & fuel gage could operate at 6 volts.... For the fuel gage, that circuit could be configured to use a 12 to 6 volt voltage reducer, then the wires swapped for ground reversal & the entire fuel gage circuit could be triggered from the same oil pressure switch that will be needed for the alternator operation..
~It would take a little work but designing a fairly straight forward 12 volt negative ground alternator equipped 12 volt/ 6 volt system would be possible..
~One of the problems you will run into if trying to use a single 12 to 6 volt voltage reducer & use the stock ignition switch resistor is the ignition switch would have to be 12 volts for the lights.. When the starter push button is pushed it by-passes the factory resistor so that would put 12 volts to the pony coils.. There is a way around that but would require the stock resistor to be removed from the back of the ignition switch & installed at the starter push button..
~If you decide to attempt a 12 volt negative ground conversion of that pony start diesel let us know & we can design a custom wire diagram & operational system around those 12 to 6 volt voltage reducers or those LM type voltage regulators Glen spoke of..
[email protected]
BMA
03-18-2004 13:55:35
 Re: Re: Re: Re: '59 730 pony start to 12 volt in reply to Clooney , 03-17-2004 15:09:06
thanks clooney and buickanddeere, you've given me something to think on,
The Idea of going negative ground had not occored to me as i was planning on using a dynamo to keep the look of the tractor right. obviously negative output ic reg's would be required, though thinking about it now neg ground has many advantages. I also already have some 3A fixed output and a few 5A varible output LM type regs.
so working on clooneys suggestion use 1 reg fed though a recitifer diode from D+ on on dynamo or ind on alternator, the press to test button is also connected to the input and the output feeds fuel gauge. another reg fed from the ingnition switch to supply coils. now is it best to put orginal resistor inline between reg output and coils input with reg output set at 6V or simply set reg output to 4.5V and direct to coils?.
one last question changine coils to neg ground is it just a case of swaping over the leads on both coils.
P.s. i am actually working on an 820 though i assume system is the same for all v4 pony motors.
many thanks for all your help. Barry
Clooney
03-19-2004 07:09:22
 Re: Re: Re: Re: Re: '59 730 pony start to 12 volt in reply to BMA, 03-18-2004 13:55:35
BMA, on the fuel gage voltage supply.. You shouldn't need a diode if using a 12 volt generator [dynamo].. You can just leave the production wiring from the test push button the same & leave the fuel gage power wire hooked to the generator's [A] post or regulator's [GEN] terminal the same, then install one of those 3 amp fixed output LM's in the power wire right at the dash gage. That way the fuel gage system would operate the same as production, only the circuit would be 12 volts, then the 12 volts would be modified to 6 volts right at the gage using that LM.. If using an alternator-- actually you would use the contacts of the oil pressure switch you would need to install to power the alternators excitation circuit, you might need a diode it that set-up..
~On the ignition question, I guess before an informed decision could be made on that, a measurement of the current needed to run the pony distributor coils would be needed.. I would hook my DVOM [ammeter] in series with the pony distributor power wire & measure the running pony,, pony off/ ign switch on,, & cranking amps going to the pony distributor coils.. If it is low enough to power those pony coils with a single LM or voltage reducer I would install a single 6 volter at the dash area & use the production ignition resistor in the pony distributor power supply line.. That way it could be configured to also retain the by-pass starting & production trouble shooting procedures�.If the current needed to run that pony distributor is too high for a single LM or voltage reducer then a separate 4.5-5 volt LM on each coil feed pig tail inside the pony distributor would probably be the way to go..
~One thing I would look closely at is the failure mode of your power regulator or reducers.. If they fail open [or go open if their mounting comes loose] it�s no big deal but if they fail closed & allow full input voltage through I would be concerned with a failure mode allowing 12 volts to fry those fragile pony coils..
~On the pony coil polarity swapping? As Glen said it won�t help.. Those pony coils spark 2 plugs at once so 1 plug of the 2 is always sparking at reverse polarity.. If you change the coil polarity it will just mean the plugs will swap polarity from on to the other so the other plug will then spark at reverse polarity [no gain]..
~Keep us informed on your progress if you decide to make the 12 volt swap as we [We being Glen, Myself, & Frank] have talked about this conversion in the past & think we have it pretty well figured but there is nothing like the real conversion to prove or dis-prove all our theories..
[email protected]
buickanddeere
03-18-2004 14:17:01
The starting engine coils are not polarity sensitive as the primary/secondary windings are independent. Not an auto transformer design used in the classic �ignition coil" which are polarity sensitive. Even a 5 amp regulator will be maxed out feeding one coil let alone two. The starting bypass circuit just kept about 4.5V across the coil when the 6V starting system was dragged down while spinning the starter over. The 12V supply even if it drops to 10.0V while cranking will still maintain regulated 4.5v through the coils. If the solid state rather than ballast resistors are used. By chance are you located in Europe or have some influence from there? FIT's and Clooney's coil feed through a pressure switch is an important feature to add. I got fooled once after working on the 70D but before taking a detailed look at the 720D. Thought for a while there was a oil pressure switch on the 720/730's tied to the ignition coils on those right from the factory.
BMA
03-19-2004 15:16:10
 Re: Re: Re: Re: Re: Re: '59 730 pony start to 12 v in reply to buickanddeere , 03-18-2004 14:17:01
Thanks guys.
its gonna be a few weeks before i get any time to try this on the tractor but in the meantime i am going to try to kill a few 5V regs just to check to failer mode.
Yes i am from U.K. what gave me away? weird posting times or unusual terminal id?
I will let u know how i get on.
Thanks again Barry.
buickanddeere
03-17-2004 13:46:56
Off the shelf three lead regulators are tough to find larger than 3.0 amps and I've never seen bigger than a 5.0 amp unit. If feeding the coils 4.5V to 5.0V directly off a regulator(s) fed from 12V a bypass starting circuit is not required. System voltage will always stay high enough even when cranking.
J.R.
03-16-2004 17:18:22
The reason I asked is that I burned the 6volt coils I think. Would it just be better to rebuild the distributor and buy a 6 volt battery? This is a positive ground system, right?
Thanks for your help!
F-I-T
03-17-2004 07:15:16
 Re: Re: Re: '59 730 pony start to 12 volt in reply to J.R., 03-16-2004 17:18:22
J.R.:
If you only burned out the coils, and the rest of the pony is mechanically pretty sound, I think you might be ahead to just fix the spark. I bought a do it yourself distributor kit from Magneeders" and it contained points, condensors, sparkplug wires and coils. Others sell them as well.
Clooney and I wrote an article for Green Magazine awhile back about installing a pony coil protection circuit. Briefly, it consists of an oil pressure switch which only allows power to the coils when the pony is making pressure. That way, when you (not if....cause you will) accidently let the switch "On", you won't have to worry that you have burned out the coils. I have the article posted on my website under "Restoration Tips". I will never have another two cylinder diesel with pony start without this feature. It really, really works.
If you are going to fix up the pony, check that the pony carburetor has a newer float. The old ones were cork and they used to breakdown and clog things up. Also, you might want to freshen up the starter with some new brushes (you need all the help you can get with 6 volts), nice tight and clean cables, and new sparkplugs. Set the points accurately, maybe touch up the timing using a light, and you be surprised at how well that system works.
I sure have nithing against electric start, but a properly operating pony system is really hard to beat, especially in cold weather.
Oh, BTW, it is a positive ground, 6 volt system.
Frank-in-Tallahassee
'56 70D // '90 855 // '50 VAC // '48 Farmall Cub
[email protected]
Bo in Maryland
03-17-2004 12:32:22
 Re: Re: Re: Re: '59 730 pony start to 12 volt in reply to F-I-T, 03-17-2004 07:15:16
F-I-T mentions...."a properly operating pony system is really hard to beat, especially in cold weather."
..... that has been my experiance..... ..my neighbors all have newer tractors than my 730D pony..... guess who always got his tractor started this January without ether or jumper cables?.....
Good luck to all!
Bo
buickanddeere
03-16-2004 20:28:36
Green Magazine and Two Cylinder both have ads for coil kits/wires/capacitors/points. The coils using the "spring" clip wire retention rather than the "spike" are prefered. All two cylinder Deeres and New Generation with generators were positive ground. 24V systems were taped for - and + 12 ground. If the coils smell like smoke, they are ruined.
