EARLY B STEERING WHEEL REAR WHEELS
ROB
03-16-2004 15:01:54
Hi All,I have an early 4 bolt B with a center fill gas tank.The steering wheel on it has round spokes,should it have flat spokes instead?My 34 A open shaft has a flat spoke steering wheel on it.Next question ,the B has round spoke rears,one has a center valve stem , the other has the valve stem on the side.They have not been repaired or altered.Should they both be the center valve? Thanks for any info! ROB
GPWT
03-16-2004 17:32:01
 Re: EARLY B STEERING WHEEL REAR WHEELS in reply to ROB , 03-16-2004 15:01:54
Your center fill B (or any US B) should have the flat spoke steering wheel. The OFS A should have a flat spoke steering wheel with the triangular shaped hub. I believe the round spoke rears with the valve stem in the center are older and thus correct for your tractor.
Duane Larson
03-16-2004 18:18:32
 Re: Re: EARLY B STEERING WHEEL REAR WHEELS in reply to GPWT, 03-16-2004 17:32:01
Wes Malcolm in his book on the Unstyled A notes the change from center to side fill valve stems occurred in early 1936, and since F&H used the same 6.00Sx36 rim on both the A and B, the change for the B probably occurred about the same time.
