Cooling system on 49 D, Help Mr. Clooney
Wes
03-16-2004 14:53:16
I found a hairline crack that I noticed when I was cleaning up the bottom of the bottom tank. I have had the tractor for six months and it had not been leaking, but after I removed the krud and some rust I now have a small seep along this crack. I believe that this crack has been there a long time. Crack is maybe three inches long. Not much just a drip ever now and then.
I'm not sure as how to fix. Would JB Weld hold it? Or add alluminum or Barrs stop leak? What does the whole thing weigh if I need to remove it from the tractor? I'm sure a machine shop can weld it. The radiator is in execellent shape except for that .
Any help and ideas would be appreciated.
Thanks
Wes
Wes
03-16-2004 17:48:40
 Re: Cooling system on 49 D, Help Mr. Clooney in reply to Wes, 03-16-2004 14:53:16
Clooney,
The crack is in the middle flat part of the bottom, about 6 inches from the right side. Not on the flange, corner or in a stress point. Would the JB Weld hold,I have never used the product, just heard about it. Tell me what you think about whick product would be your first choice. It still gets cold here in Missouri so I have antifreeze in it.
Thanks
Wes
Clooney
03-17-2004 11:08:48
 Re: Re: Cooling system on 49 D, Help Mr. Clooney in reply to Wes, 03-16-2004 17:48:40
Wes, I would use JB weld as a last resort.. Once you seal the outside the stop leak won't work.. That stuff needs to see air to work.. Try sealing it from inside with a stop leak product & if that fails you can always scuff the outside & use JB weld...
As far as product I can't really say, Bars Leak has always worked good in old cars & water pump equipped tractors & Block Sealer works good in old hit & miss engines.. The Block Sealer might be a little much for that D as it could plug the radiator..
[email protected]
Wes
03-17-2004 16:58:01
 Re: Re: Re: Cooling system on 49 D, Help Mr. Cloon in reply to Clooney, 03-17-2004 11:08:48
Clooney,
Thanks for your insight. I appreciate your help.
When it gets a little warmer I will drain and fill with water and see what happens.
Wes
Clooney
03-16-2004 15:31:03
Wes, a lot depends on if the crack is in a structural area or just in the center of the lower casting.. If it's in an area that doesn't have much stress on it I would just say to use a stop leak type product.. Those work excellent on hair line cracks that don't move or open up under force or heat expansion.. The problem you will have is getting that stop leak to work on that thermosiphon system.. You will probably have to get it very hot, then either use a pump attached to the lower block drain, or slowly drain it into a bucket & keep pouring it back into the radiator.. If the temperature is going to stay above freezing you might just use plain water in it for a while as rust makes a very effective crack seal.. If you ever pull the radiator out then you can have it welded or pinned..
~As for radiator weight? I can't say for sure as I haven't ever weighed one but I can't get one off the tractor without a strap & come-along or chain fall.. Once off the tractor I can just barely move it around & lift it by hand so I would put it in the mid 125-150 lb range.. [Heavy but handleable]....
[email protected]
Wes
03-16-2004 19:00:09
 Re: Re: Cooling system on 49 D, Help Mr. Clooney in reply to Clooney , 03-16-2004 15:31:03
Clooney,
Thanks
Wes
JC
03-16-2004 15:09:08
Wes,
Clooney can help u with repair advice.
I just put my bottom tank back on. The gasket is available from Deere. The sealing surface on my bottom tank was quite pitted from rust so I really cleaned it well and used a wire wheel on the angle grinder to clean it up.
The whole assy weighs about 100 to 150 lbs. We used an engine crane and nylon lifting strap to lift it off initially but two people can easily handle it around the shop. It's more awkward than heavy.
Good Luck,
JC
Wes
03-16-2004 19:06:08
 Re: Re: Cooling system on 49 D, Help Mr. Clooney in reply to JC, 03-16-2004 15:09:08
JC,
The JD Dealer has the bottom gaskets D294 R, but they say the top gasket D3008 R is out of stock. Did you get top gasket for the upper water pipe or make it, if so out of what?
Thanks
Wes
JC
03-17-2004 04:05:50
 Re: Re: Re: Cooling system on 49 D, Help Mr. Cloon in reply to Wes, 03-16-2004 19:06:08
Wes,
My tractor is an unstyled D 1938/1939 with s/n 143,xxx and it may be different to yours.
I got the large gaskets for the upper and lower tanks as individual gaskets from Deere. My parts book shows D295R for the top-of-water pipe to radiator gasket. That gasket came in gasket kit AD2675R but may be available as a loose piece.
My parts book for unstyled Ds doesn't show D3008R so your newer tractor may be different.
Aside - I'd double check with another Deere dealer. My local parts guy is starting to grown when I ask for some of the old, low cost parts because he says Deere is requiring him to take some of these parts in lots of 5 pieces and he knows he will likely never sell the remaining 4 that I leave behind.
If I couldn't get that gasket, I'd get a piece of thick "vegetable paper" gasket stock and make it. It's a simple gasket. That paper stock is available at any gasket speciality shops. Most small-medium sized cities have at least one. The material is very inexpensive. It comes 3' wide and sells by the foot!
I would coat the mating surfaces with lots of gasket sealer to make sure that you fill all of the voids in the cast iron and the irregularities along the mating surfaces.
JC
