3PT 800 VS 801
Kevin
03-16-2004 14:41:24
800 3PT VS 801 3PT is one better? how are they different? I'm looking for a 3pt which one would be a better choice? Thanks for your help Kevin
Clooney
03-16-2004 16:04:12
 Re: 3PT 800 VS 801 in reply to Kevin, 03-16-2004 14:41:24
Kevin, neither the 800 or 801 are a true 3-point hitch. They will work as a 3-point with the correct adapters.
~About the biggest difference is that the 800 is just a standard type hitch & the 801 is a load control type that uses extra links to control position..
~It's hard to say which one is better, that would depend on what you want to do with or use with them.. If just a back blade, or scraper, or brush hog, or mower then the simpler 800 will work just fine.. If plowing or in other applications where you want some load control then the later more complex 801 is probably better..
~If you are just looking for a good working easy to hook up & easy to use 3-point hitch with good positive sway control then an aftermarket 3-point would probably be better than either the 800 or 801..
[email protected]
