TIRES
70 PLOWBOY
03-16-2004 14:25:57
My brother has a 720 standard with 15~30`s in the rear Well he saw one with 23.1~30`s now has to have them?! anyways know where he can get a rim to fit this tire and still bolt up to his centers?? he said 18.4 wernt big enough did they make something in between a 18.4~30 and a 23.1~30???
thanks for any info ROD
scottAR
03-18-2004 19:08:47
 Re: TIRES in reply to 70 PLOWBOY, 03-16-2004 14:25:57
Try a rim from a 930 Case tractor. I used to have one that had 23.1X30 and it was an open center rim. Also, I had a Steiger Bearcat that had 23.1X30 on the inside with 18.4X34 duals but the inside ones are not open center.
Clooney
03-16-2004 14:40:23
Rod, are you sure those tires weren't 23.1 X 26, I haven't ever seen a 23.1 X 30?..
[email protected]
buickanddeere
03-17-2004 06:34:39
 Re: Re: TIRES in reply to Clooney , 03-16-2004 14:40:23
I missed them the 1st time through the Firestone site too. There are 23.1x26 low profile, regular 23.1x26, 23.1x30 and 23.1x34. Alot of tire for a tractor with such fast gearing in 1st and reverse while weighing approx 8000lbs and only having 52HP.
70plowboy
03-16-2004 16:07:08
no CLOONEY he said 23.1`s ~30 he has found the tires but the rim is the problem for him.
IF he cant find a rim in 30` is there centers that would fit his axels that would permit the use of 26`rims then our uncle has a 820 with big tires i think he`s going after that look but it has bolt on 26`rims is there a set up that would allow 26 rims to fit his tractor ?
thanks clooney
ROD
buickanddeere
03-17-2004 13:49:30
 Re: Re: Re: TIRES in reply to 70plowboy, 03-16-2004 16:07:08
There are 26" cast centers that fit the 70/720/730. The rim width will have to be 24" to assist getting the tread bars spread on the ground.
Mike Aylward
03-16-2004 16:33:11
70Plowboy, there are a couple of ways you can do this. One is to use the tractor puller's trick of widening the rims you currently have with a weld-in band. The other way (and probably the easiest way) is to find a 4010 or 4020 Standard in a salvage yard with that size tires and purchase the rims. I believe they will fit right on your center castings. But check the width before you buy, as a tire that wide should have at least a 20" rim and even 21" or 22" wouldn't be too wide. A rim narrower than 20" will not be wide enough to function or look right. Hope this helps. Mike
Russ
03-17-2004 04:13:56
 Re: Re: Re: Re: TIRES in reply to Mike Aylward, 03-16-2004 16:33:11
Tired of narrow? If you can afford the time and money by all means shoot for the moon.
If you just want that look on you fireplace mantle try trick photography you'll get a beautiful 8" x 10" for braggin' rights and then
you can tell all your friends that fad moved
on fast and your in to other things now.
Just a thought. Good luck on your wide period.
70 plowboy
03-16-2004 17:16:16
thanks MIKE thats what we were looking to hear ROD
