2nd remote for 4020
S. Conner
03-16-2004 10:08:38
I've got an early model 4020 that I'd like to add a second remote on. I just thought I'd check on here to see if anybody knows where a guy could get the parts to do this. For years I thought these tractors all came from the factory with both remotes until I started looking around for one. The one I bought was in such good condition that I thought I could live with one remote. Everybody around here that has a 4020 bought it with both. Thanks for the input.
Rodney A. Johnson
03-17-2004 10:58:04
 Re: 2nd remote for 4020 in reply to S. Conner, 03-16-2004 10:08:38
Any 3010,3020,4010, or 4020 parts will work for the couplers in the back and the valve up front (early model 20 series). The stuff that is different is the longer bolts needed to bolt the valve onto the bottom of the current one, the extra long bolt, spacer, and lever to hook up to the valve, and lastly the metal lines running from the valve to the coupler.
Note that the 10 series has smaller lines (3/8 vs. 1/2 inch if I recall correctly). Many have suggested to just use a hydraulic hose instead of the steel lines.
You may have to tap and drill if you put a 10 series coupler on, as I think the holes are exactly opposite as the 10 series (at least for the second remote). I put a 20 series setup on my 3010, and had to drill and tap to attach the couplers.
You can buy rebuilt couplers and valves, but will run you around 500USD for each. If you get lucky like I did, you might find an extra set at auction and pick the whole set for less (I got mine for 360USD at auction about 5 years ago).
thurlow
03-16-2004 19:31:59
I've done several; just picked parts up at salvage yard; 10 or 20 series box will work at back; been a while, not sure about valve box under hood..... I've just used hydraulic hose, rather than "correct" steel line.....
david val
03-16-2004 14:29:21
if you are looking for a used one, 3020 parts of that era shoult fit too. david
Ray
03-16-2004 13:52:17
I've got an electric remote that the JD dealers
sell.We had it on a 4020 and a 4430.I don't need
it anymore,I'll take $200.
Bob
03-16-2004 10:28:59
I don't think the parts would be too hard to come by from a wrecking yard, but there are quite a few individual parts needed, and I'll bet it won't be cheap!
If function is more important than originality, have you check out one of the various hydraulic multipliers? These aren't cheap either, but they're quick and easy!
Link
Link
