70 Diesel batteries
deere k
03-16-2004 06:57:18
I think I have found 2 new 12v batteries to fit in my seat box for this diesel tractors home made 12 volt electric start system. Its negative ground. I will use super duty cable to tie it all together, but the question is what is the correct way to link these to the starter to be 12v, not 24v?
Tie the two negatives together, take to a ground post and on the positives, link the two together and run one line to the starter, OR
Tie the two negatives together, take to a ground post and on the positives, run one line off each to the starter.
Tanks
Clooney
03-16-2004 16:29:13
 Re: 70 Diesel batteries in reply to deere k, 03-16-2004 06:57:18
Deere K, as mentioned below hooking both negatives to the tractor frame & both positives to the starter is the way to go..
~Now on how to do it??
~I just want through a similar situation a year or so ago so can add a little here...
~You are going to have a hard time hooking those battery cables together at the battery posts then to ground or the starter.. I would suggest you run a separate ground cable from each battery's negative post directly to the seat box mounting bolts.. If two separate cables are used they can be 1-0 cables with ring terminals on the frame mounting ends.. Be sure to run a tap in the seat box mounting holes to clean the rust out so you get a better ground connection...
~For the cable from the batteries positive posts to the starter,, a good way to go is to mount a plastic isolated 3/8" binding stud in the battery box, then run a 1-0 ring end cable from each battery's positive post to that binding stud, then run a 2-0 cable from that binding stud to the starters battery cable post.. You can then also attach the battery feed & charging wire that runs from the ammeter to that binding post [that makes a real sanitary installation]..
[email protected]
John T
03-16-2004 07:37:39
Deere, you and the good Frank are on the money (two 12 volt batteries in parallel), the only thing I might add is to use those good heavy duty semi truck type battery cable ends and connectors, and I would use 00 Gauge cables also. I like the felt washeres on the posts under the connectors then sprayed with the battery terminal protector spray. The 12 volt starter solenoid needs to be a high current rated, not a light wimpy automotive duty type which might weld shut. As much as possible, get the ground connection to a solid heavy frame member and/or close to the starter as possible versus a connection to any light tin seat or battery box. Dont forget to set up the charging system for negative ground if you havent already including polarizing it and maybe having to reverse the ammeter leads.
Good luck with her n God Bless
John T
buickanddeere
03-16-2004 09:04:19
 Re: Re: 70 Diesel batteries in reply to John T, 03-16-2004 07:37:39
When the 2/00 or 4/00 welding cables are cut to length take then to your friendly local electrical contractor. They have the HD lugs and hydraulic clamps to swage them on. Don't use the Wal-Mart automotive clamp at the batteries. High current levels on a low voltage system are required to make enough cranking power. Cannot afford any voltage drop and/or the heating/melting of connections. A bronze bolt right on the starter mount with the "ground" directly attached to the starter body will eliminate many problems now and later. What is on there for a charging system and what was adapted for the fuel gauge supply? Did you use the 720/730 24V battery box under the seat or the old 6V ?
F-I-T
03-16-2004 07:02:09
Deere K:
What you want to do is called hooking in parallel. You had it right when you said..."Tie the two negatives together, take to a ground post and on the positives, link the two together and run one line to the starter,...".
Plus to Plus, Negative to Negative. How you mangage the positive through the starter switch is up to you.
Frank-in-Pasadena
Deere k
03-16-2004 07:17:21
 Re: Re: 70 Diesel batteries in reply to F-I-T, 03-16-2004 07:02:09
Good show Frank, thanks!
