Do I pull the head??
mwilkinson
03-16-2004 05:53:41
I have a 49B I am restoring, My question is do I pull the head and do the rings and hone the cylinder or not. The governor is off and I can see the back of the cylinder walls and pistons. They are clean shinny and smooth. The tractor is free and was never stuck. It had been in a building its entire life. I only plan to pull a hay rack for hay rides a few times a year and go to a couple of shows. Any opinions would be greatful. I am getting tired of staring at the thing trying to decide what to do.
mwilkinson
03-17-2004 05:47:48
 Re: Do I pull the head?? in reply to mwilkinson, 03-16-2004 05:53:41
Ok, I am pulling the head doing the rings and valves. I plan to pull the head this weekend. I will mark all parts, clean and have about a million questions on Monday. Thanks for all of the comments.
Mat
Russ
03-16-2004 15:24:19
Deere Motor; If you have the time, talent and money go the Clooney option.
Otherwise with the minor pulling and frequency of use you describe could lend to doing the get by
scenario. If the magneto is working fine, put in a set of new plugs, fresh fuel and top off the battery with a charge.
If you feel all charged up do a pull test in first gear of your truck with the brakes applied after your rolling and pulling the load forward.
Look to your exhaust stack and see if it is pushing blue hazy smoke. Sounds like you have got a solid running value and she is soon to be pulling those occasional loads with not much further investment.
Clooney and John T. seem to always have solid
worthwhile recommendations for so many inquisitors.
ChuckW
03-16-2004 14:26:00
have been in that delima many times....usually will go on in as Cooleny suggests and will find a broken ring or two. I'd rather know than to wondered and have a smoker later on.
buickanddeere
03-16-2004 20:32:49
 Re: Re: Do I pull the head?? in reply to ChuckW, 03-16-2004 14:26:00
I agree with the head removal. Do it and sleep well afterwards. New guides at the same time can't hurt.
Clooney
03-16-2004 09:07:29
mwilkinson, I guess I have a different opinion, as long as you are into it that far it would be a shame not to do a complete job.. It only takes a few minutes to pull the head & pistons & that way you won't have to go back in after it's back together to install rings or do a valve job..
~Just because the back of the cylinder is clean & shiny doesn't mean the front compression part is also good.. There is usually very little wear at the back of the cylinders so looking at the rear won't tell you very much..
~If the cylinders are in good shape all you will need is a quick hone & new rings.. That way you will get a new head gasket so future leakage won�t be problem & if the valves are starting to lose a good seat it would be a good time to do them also..
[email protected]
John T
03-16-2004 08:38:09
I agree with that below, If she has decent compression, especially if about the same on BOTH cylinders, often as evidenced by the lack of excess blow by and not any oil burnign blue smoke out the stack caused by ring or valve guide problems, and shes not mixing oil n water (good head gasket seal) I would leave the old girl alone.
Best Wishes n God Bless
John T
2 Cylinder
03-16-2004 07:36:22
If she starts and runs, and don't smoke, leave alone. If she runs, don't tear it apart to see why.
Tim...OK
03-16-2004 06:59:37
If it ain't broke,I don't think I would try to fix it.Maybe a little MMO in the plug holes and turn it over occassionally while you are working on other parts of it. That should make sure the rings are lubed up good for start up time.
Tim
