40 John Deere Carburator question?
Jack
03-15-2004 14:37:45
Got a 40 Standard in the shop that doesen't want to idle down low due to sucking air around the throttle shaft.I called John Deere dealer and I can get the shaft for 40.00 and a packing kit for about 7.00 but when I asked for the bushings I was told that the book don't show them.Is the only thing that can be replaced the shaft and felt and no bushing and hope that is enough to take up the slop,or will I need to be finding a carb housing somewhere?On the DLTX 51's,71's and ect.I could get bushings and all,whats up with this one?Any help would be appreciated,thanks.Jack(TN).
Duane Larson
03-16-2004 06:28:18
 Re: 40 John Deere Carburator question? in reply to Jack, 03-15-2004 14:37:45
Jack,
Throttle shaft casting holes in the TSX carburetors do wear after a period of time, especially if work was done in dusty conditions. A tool was sold in the '50's to line-bore the throttle shaft holes. It has a two-step reamer so both the back and front holes can be bushed. Generally I don't have to bush them, but it does happen. Try a new throttle shaft and rubber seals first, and if that doesn't tighten things up, your carb may be a candidate for a bushing job.
JDM Guy
03-15-2004 15:16:32
Those shafts are softer than the carb housing so they wear out and no the housing. I got the shaft for my TSX 530 carb for 19$ from Roberts carb repair. I think the 40 came with a TSX 530 carb, I got a old carb off e-bay and it was for a 40. The M that I'm working on originaly came with a TSX 245 carb but I guess the 40 carb works to. But any ways those shafts can be purchased alot of places.
Clooney
03-15-2004 14:58:09
Jack, no throttle shaft bushings in the Deere 40 TSX carb.. In most cases a new throttle shaft & packings will stop the air leak at the throttle shaft..
I always install new shaft packing any time I pull a throttle shaft from those TSX carbs..
[email protected]
