1010 gas compression reading
lloyd
03-15-2004 14:08:21
I'm working on a 62 JD 1010 gas and have a question on compression readings. #1 172lbs, #2 160 lbs, #3 170 lbs, #4 180 lbs. All hold pressure well. # 2 had a little carbon on the plug. This had set in a barn for at least 6 years. I lubed the pistons prior to turning it over with the starter. My question is this something to address or to just monitor. Thanks in advance , lloyd
Clooney
03-15-2004 15:04:10
 Re: 1010 gas compression reading in reply to lloyd, 03-15-2004 14:08:21
Lloyd, if you oiled the pistons first you could have a ring problem & not even know it.. That lower compression cylinder could be some rust on the valve face or seat..
~You probably should run [or work] it for a while then do a hot compression test with the choke & throttle wide open.. [that will tell the story]..
~That compression you have now sounds pretty good for an engine that has been sitting that long.. BUT, it might not be true if you have oiled the piston rings first.. You need to re-test without the pistons oiled...
[email protected]
old
03-15-2004 14:49:26
Those are not bad readings but the one is a little off so to speak but it should be ok as it is, just means that one cylinder my have worn rings and or one stuck which may work its way out after working it some
lloyd
03-15-2004 17:53:26
 Re: Re: 1010 gas compression reading in reply to old, 03-15-2004 14:49:26
Thanks all, sounds like a solution I'm good at (wait & it just might go away) Ha! All this time & I was applying sound enginering principles to most of those "honey dos". lloyd
Bob
03-15-2004 18:23:41
 Re: Re: Re: 1010 gas compression reading in reply to lloyd, 03-15-2004 17:53:26
"Work" the tractor for 50 or 100 hours and then check the compression again.
