49 Model A - Water in Cylinders
Lee
03-15-2004 13:08:52
My 49 Model "A" always ends up with a cup or so of water in each cylinder after sitting for a month or so (in the barn). Any thoughts on what would cause the problem would be greatly appreciated!!! Starts and runs like a champ once I get the water out. Thnkx!!!
Lee
03-16-2004 06:27:04
 Re: 49 Model A - Water in Cylinders in reply to Lee, 03-15-2004 13:08:52
Thanks to all! I appreciate all the info and it will help me get started. The darn thing sure runs great and pulls like a moose so I am sure that I will get her fixed up.
g pop
03-16-2004 04:57:33
lean toward a head gasket,most of the time when a head or block cracks it is on one cylinder or the other.
Other Lee
03-16-2004 04:16:11
Cracked head/block or a bad head gasket are the usual culprets for an A. Cheapest solution is Bar's leak until the Bar's leak can't hold it back anymore. Considering the risk of finding the first items mentioned, I wouldn't replace the head gasket until the funds were in place to take care of those, if found. Head gasket is around $50, cracked block repair is around $300 and in my experiance is wasted money as I still have a 'leaker' 43 A. So now you are looking at $400-$500 for a used block and boring job on it, new pistons $300?, etc. VS Bar's leak at $3.00 a bottle. I have to run 4 large bottles of Bar's leak to avoid an unscheduled green shower at startup, so my case should be considered to be extreme to insane use of Bar's leak.
On the other hand, your minor leakage amount, if consistant, just screams 'head gasket' to me so a replacement shouldn't be as costly as my fix above was. And if it IS a head gasket, then one bottle should fix it, if it takes more than 2 to get it under control then I would start to worry and seriously think about whole tractor replacement for the same money as a new block, boring job, pistons to match, time down, hassle, etc. There is the old mechanics joke which does apply in the extreme case like mine, the fix is - remove radiator cap and roll a new tractor in under the cap and reinstall the raditor cap.
Jeff W
03-15-2004 16:59:11
Yes you do have a problem. I had the same problem on my B, and found out that the pushrod tubes that go through the head were leaking. On the ends of them they are flared out, and thats where they were leaking at. A buddy of mine with a machine shop pressure tested it for me and found it. Just somthing else to check maybe.
Will P
03-15-2004 17:52:05
 Re: Re: 49 Model A - Water in Cylinders in reply to Jeff W, 03-15-2004 16:59:11
Starting in 41, the A lost all of its push-rod tubes. So that is not the problem.
Will P
James
03-15-2004 16:31:01
Lee you prob. have a leaking head or gasket so you may try some stop leak in it first and that may get you by a while . That's what I would do .
old
03-15-2004 13:16:44
A leak in the roof?? Is the rad still full? Condensation? Just guesses but any of them could be the problem.
Lee
03-15-2004 13:26:33
 Re: Re: 49 Model A - Water in Cylinders in reply to old, 03-15-2004 13:16:44
No leak in the roof. The Radiator may be down some. Not sure about condensation. Thankx!
old
03-15-2004 14:31:01
 Re: Re: Re: 49 Model A - Water in Cylinders in reply to Lee, 03-15-2004 13:26:33
Always happy to give ideas on what maybe wrong. I think I'd check the rad/head gasket since I never have condensation problems with my B in that way.
