H serial numbers
J.P.
03-15-2004 13:02:32
My recent copy of green magazine and the chart elsewhere on this site do not match as far as the serial numbers and number of Model H's manufactured in 1944. We have a '41 model and one that by any source so far that is a '44; havn't yet decided which is "Peter" and which is "Paul". The question still remains - How many were made in 1944? Can someone please help with a definitive answer?
James
03-15-2004 16:46:21
 Re: H serial numbers in reply to J.P. , 03-15-2004 13:02:32
The Data book by Dunning says that ser. # 47795 was the last with cast wheels built on Sept. 29th 1943 before a halt in production and ser. # 47796 first with steel front wheels built on Oct. 9th 1944 when production resumed. Now this is what this author says from His research. My 2 cents worth. The beginning # of 1945 was 48392. if that helps Good Day Sir
dan_41jdh
03-15-2004 19:24:33
 Re: Re: H serial numbers in reply to James, 03-15-2004 16:46:21
James, although the serial number list on this website, along with the original "John Deere Tractors 1918-1976" and the original Two-Cylinder Club wallet cards and many other similar copies show the beginning serial number of the 1945 model year was 48392, they now say it is 47796. Apparently, the revised numbers come from specific "notes written in the original serial number registers", according to Green Magazine (Dec '96). Also, the Mar-Apr '99 edition of Two-Cylinder says, "Incidentally, 47796 was also the first serial number of the 1945 model year". Both Green Magazine and Two-Cylinder agree about the production interruption and serial numbers on Sep '43 to Oct '44.
Stan - Florida
03-16-2004 03:50:38
 Re: Re: Re: H serial numbers in reply to dan_41jdh, 03-15-2004 19:24:33
Dan, You're absolutely right about the serial number errors in the "brown book", published in 1976. Those were indeed acknowledged and corrected in the "gray book" published in 1994, and are most likely the basis for serial number listings used by Green Mag and 2-Cyl.
Stan
dan_41jdh
03-15-2004 14:03:00
J.P., the serial numbers on this site for the H came from an original list that John Deere published in 1976. Subsequently, John Deere, the Two-Cylinder Club and Green Magazine have discovered problems the with original list and have published "corrected" beginning serial number lists. Again, these lists are considered to represent the MODEL YEAR, and not necessarily the production year, fiscal year, or calendar year. Anyway, for the 1944 model year, there were 2154 serial numbers "used". However, some of those numbers may have been scrapped or not used. I haven't seen anyone publish the actual number of model H tractors produced in 1944.
J.P.
03-15-2004 17:20:58
 Re: Re: H serial numbers in reply to dan_41jdh, 03-15-2004 14:03:00
Thanks,
Every little piece helps to make the picture a bit clearer. It does seem however that the '44 is more likely to be "Paul" with such smaller production numbers.
