2-14 trip plow
JD-A
03-15-2004 11:54:40
Have a Deere 2-14 trip mouldboard w/ an HO44 or HC44 number on a cross beam, can't tell which would be right. It needs new 16" rims would it be a sin to replace with newer auto rims? This is a bolt togather plow, also have a Deere 2-14 mould board w/ steel wheels and it has bent beams that the plows are conected to. Have no clue what it is other than it has John Deere stamped on each plow beam. Please post any info on painted colors, Thanks in advance
Wingman
03-15-2004 15:41:33
 Re: 2-14 trip plow in reply to JD-A, 03-15-2004 11:54:40
What St.do you live in. I have extra wheels
Bob Collins
03-15-2004 14:31:28
JD-A, You have seen it and I haven't but I'd guess it says "NO. 44" meaning it is a number 44 plow. The 16" rims were used until 1952 and after that 15" rims were used. If you want an original appearing plow I suggest using one of those sizes, your depth adjustments will be easier if the diameter of the tire is near original too. I can't think of any way it would be considered sinful to do as you wish with your own plow, unless maybe you stole it to begin with or intentionally did someone wrong using it. Generally you be right on making the frame and attachments green and the wheels yellow. Bottoms could be black or silver on the working surface and black or green on the backside. One requirement if you intend to plow with it is to enjoy it.
JD-A
03-15-2004 20:02:43
 Re: Re: 2-14 trip plow in reply to Bob Collins, 03-15-2004 14:31:28
Didn't steal it and already plowed many miles with it while I was in high school, just wanted to restore it. I did enjoy those hours ridin' a tractor in south central Oklahoma.
TG (OT Reply)
03-17-2004 19:59:17
 Re: Re: Re: 2-14 trip plow in reply to JD-A, 03-15-2004 20:02:43
I'm in Durant. Where are you?
JD-A
03-21-2004 14:20:11
 Re: Re: Re: Re: 2-14 trip plow in reply to TG (OT Reply), 03-17-2004 19:59:17
North of McAlester
