Timing of a styled B with Electric start
Firfighter
03-15-2004 08:08:23
How is this done the IT manual doesnt go over a styled electric start is it the same as a unstyled wit the marks on the flywheel and bearing cover thanks again!
John T
03-15-2004 09:32:06
 Re: Timing of a styled B with Electric start in reply to Firfighter, 03-15-2004 08:08:23
The timing is still similar, youre looking for top dead center (TDC) of the left piston, and thats when the Left Hand Impulse timing mark on a flywheel is at the 3 o clock position, and on a flywheel covered tractor, its also when the timing mark on the flywheel is lined up at the bottom with the cover mark as you mentioned, i.e. same point, left piston is at TDC.
Thats when a mag would snap to fire or close (depending on where distributor is rotated) to where (if all is correct) the points would break open on high cam to fire the left piston via the distributor caps leading terminal at TDC of its compression power stroke.
If you retard (rotate max CW) the mag or distributor, bring the left piston to TDC (LHI at 3 o clock and flywheel timing mark at bottom matching mark on covers bottom) then slowlyyyyy advance the distributor CCW till a mag snaps or the points break open and fire the coil on a distributor, youre gettign close.
A timing light on the left plug wire and pointed at the bottom of the opening would flash when cranking indicating the left plug firing at the bottom flywheel mark but then show an advance in firing time once running.
This is similar for most mags or Delco or even a Wico distributor if you understand the principles, regardless what you have, its the left piston at TDC youre concerned with, and you need a distributor to open its points to fire the left cylinder at its TDC or a mag to snap and fire doing the same. Some non gear reduction drive mags (Wico C or XH Series) fire at BOTH TDC's power or exhaust.
Good Luck n God Bless, post back any info or questions
John T [email protected]
Clooney
03-15-2004 09:07:32
Firfighter, on the electric start B's there are marks on the flywheel hub & flywheel cover..
~Does you "B" have a mag, or distributor?.. If a distributor is it a Delco [round body] or a Wico [oblong body], the Wico distributor looks like a Wico mag..
~If you tell us what you have for an ignition system we can give you the proper timing procedure for that �B�....
[email protected]
mwilkinson
03-16-2004 05:49:35
 Re: Re: Timing of a styled B with Electric star in reply to Clooney, 03-15-2004 09:07:32
Clooney, I have a simmilar tractor, 49B with electric start and the Wico distributor. Which I thought was a mag until I opened it, but that is a nother story. I would appreciate the timming info.
Clooney
03-16-2004 14:34:24
 Re: Re: Re: Timing of a styled B with Electric in reply to mwilkinson, 03-16-2004 05:49:35
mwilkinson, very easy,, Just pull the spark plugs [that's so you can turn the engine over easily],, then pry out the flywheel covers center cover,, then turn the flywheel in the starting direction until the dot mark on the flywheel hub lines up with the little stamped dimple in the center bottom of the flywheel cover's center hole,, then loosen the distributor retaining bolts,, then rotate the top of the distributor all the way to front,, then install a spark plug in the L/H [flywheel side] plug wire & lay on the engine block,, then turn the ignition switch on,, then s-l-o-w-l-y rotate the top of the distributor to the rear, when the L/H plug sparks stop,, then tighten the distributor down there.. That's it.. Easy as that..
[email protected]
