1938 A
Tim...OK
03-15-2004 06:58:18
third party image
It was 65 and sunny here yesterday,thought I'd take her out for a spin,this was before I found the milky oil AGAIN..
Tim
John T (Update)
03-15-2004 07:36:39
 Re: 1938 A in reply to Tim...OK , 03-15-2004 06:58:18
Sorry Tim, I hit this before I read your post below, again, Part Number AA 1615R as Push Rod Sleeves (set of 2) for an Unstyled A, SN 410,000 and up. The old place in freezer before install trick really seemed to help installing the new tubes for us. If I recall, we placed a light coat of sealer in/on the head and tube surfaces also, dont know if it helped or was actually needed, they never leaked.
John T
John T
03-15-2004 07:11:53
Hi Tim, looks like the old girl is gonna make you a nice tractor. When you say milky oil "again" have you changed her oil and filter and re filled with coolant and the problem re occurs??? Have you tried to re torque the head nuts ??? Worth a try if the head gasket is leaking. Has she had any recent head work???
Aside from the usual suspects of leaky head gaskets and or cracks if its not any other gasket problems, some of the A's had the insert type replaceable pushrod tubes through the head which could leak coolant into the oil. We had an AR which did that and when we removed the valve cover gasket we could see that water was running out the pushrod tubes. WE had the head off and placed the new tubes in the freezer then installed them in the head and shes never leaked since. On some heads people drill the manifold stud holes too deep when drilling and re tapping and punch holes in those tubes. Is there coolant accumulating in the valve cover area???
Take care n God Bless ya
John T
