CLUTCH BELT PULLEY LOOSE
FRANK
03-14-2004 18:24:41
I just recently purchased 1937 A when the engine is
not running you can move belt pulley back an forth maybe an inch or so very easey . Would like know
what the problem is and what needs to be done to
fix it THANKS FRANK
FRANK
03-15-2004 18:06:53
 Re: CLUTCH BELT PULLEY LOOSE in reply to FRANK, 03-14-2004 18:24:41
THANKS for info Yes the pulley rotates left to right
about an inch need more info on what need to be replaced THANKS FRANK
mike
03-14-2004 18:59:25
Sounds to me he's saying the pulley will rotate back and forth,that means the clutch driver disc is loose on the splines,to fix you can buy a oversize disc that may tighten it up,but if it's worn too much the crankshaft will need to be replaced also.
Clooney
03-14-2004 18:43:52
Frank, if by back & forth you mean in & out on the crankshaft, that is normal.. If that pulley isn't free to move latterly on the crankshaft the clutch won't operate properly.. An inch is a lot of movement so that means your pulley brake is set too loose.. Try adjusting the pulley brake so the pulley only moves about 1/2"or so..
[email protected]
