How to remove oil line from block???
52BMAN
03-14-2004 13:34:08
I want to remove the block from my 1952 B. There is an oil line connected to the backside of the block. Not enough room to get a wrench on it. How do I remove it. Should I remove the oil pump first and go in from the bottom? Thanks for your help.
Mike M
03-14-2004 17:21:48
 Re: How to remove oil line from block??? in reply to 52BMAN, 03-14-2004 13:34:08
You should be safe as the later B has the line attached to the main case the block should pull free.
Paul from MI
03-14-2004 14:51:21
Don't know for sure on your '52, but I disconnected the line on my '44 B inside the block. I don't recall thet it was much of a problem. Have you removed the rods & pistons? If not, they should be removed first. Good luck,
Paul
