Liquid drain cleaner to clean carb/info only
Ben.So.Tex
03-14-2004 11:57:56
I took the carb off my junk 60 took it apart put it in a bucket of hot water pour in liquid plummer and 30 min later carb was clean, put it back together and installed it on my working 60 and it works fine, cheaper than carb cleaner.
Lee
03-15-2004 01:56:16
 Re: Liquid drain cleaner to clean carb/info only in reply to Ben.So.Tex, 03-14-2004 11:57:56
Oven Cleaner is probably an even cheaper alternative and without the metal eating aspects already mentioned.
Bus Driver
03-14-2004 12:09:09
I'm sure the only parts you cleaned were cast iron. This stuff will quickly destroy aluminum and zinc.
