two cyl diesel engine miss? clooney, f-i-t
Bill R
01-23-2004 08:57:43
Just got done with some major work on the "R", radiator core, new head with valevs, injector tubes, injectors rebuilt, pumps off and new gaskets,(all diesel work done by reputable shop) tractor lugs and pulls perfect, then after some lugging let it idle, after just a short time it starts to miss on one cylinder, thought might still be air in system from repairs, but why would it pull so good? Just frustrated after so many repairs, it will probably go into the shed so i can finish some other stuff up in the shop, any ideas or comments are appreciated. thanks as always for good past advice
Bill R
A // B // GW // R Diesel
Bill R
01-23-2004 16:34:43
 Re: two cyl diesel engine miss? clooney, f-i-t in reply to Bill R, 01-23-2004 08:57:43
thanks robert and clooney, i think there may be something there with the transfer pump as mine leaks some, i also need to get the bleed plugs sealed up better also thanks for the advice
Bill R
robert -me no expert
01-23-2004 13:10:32
I just cured a slight missing flutter in a 830.It fluttered on a high idle due to a low transfer pump pressure,feeding the inj pumps.Mine I thought pulled good but did this.I think an R runs alot lower pressure but I would check it.Is it possible those transfer pump seals are leaky letting air into system?Check for good flow from tank,maybe restricted (dirt gravel etc).,Very old fuel?Or old summer fuel if your in a cold area,filters gelling up?New valve work-tight valve guide???Cracked inj line under cover ???
Clooney
01-23-2004 13:01:09
Bill, you might have a slightly sticking valve, or possibly a sticking injector.. It could even be air in the fuel system or a slight pin hole leak in the low pressure side of the transfer pump, filter, or line...
~I guess the thing to do is just run it for while & try to keep the RPM above the miss point.. If it's a valve or injector problem it might free up & work ok..
~There isn't much that will make a diesel miss so if it pulls good under load you might just have a simple air in the fuel problem or a sticking valve..
[email protected]
