730D CRANKSHAFT
R MOORE
03-14-2004 06:35:03
I need to replace the inner thrust washer.How in the world do i get the bearing off.Does the governer have to come off.thank you.
Clooney
03-14-2004 07:14:20
 Re: 730D CRANKSHAFT in reply to R MOORE, 03-14-2004 06:35:03
R MOORE, unfortunately the governor will have to come off.. That is about the only way you will be able to get the cam & cam idler gears off.. Once the cam gears are removed the gear will have to come off the crankshaft, then the L/H bearing oil line pulled loose.. At that time you can install the removed bearing housing bolts in the provided tapped holes & tighten those bolts to push the L/H main bearing housing off the case..
[email protected]
R MOORE
03-14-2004 09:56:30
 Re: Re: 730D CRANKSHAFT in reply to Clooney , 03-14-2004 07:14:20
Do i have to pull the shaft that runs up to the fan as well.I dont think there is enough room just to pry the governer up.
Clooney
03-14-2004 10:12:34
 Re: Re: Re: 730D CRANKSHAFT in reply to R MOORE, 03-14-2004 09:56:30
R MOORE, no, you will have to unbolt the fan shaft front bearing housing [or P/S pump] from the front, then unbolt the fan shaft tube from the governor in the rear... Then slide the fan shaft forward as far as possible, the governor should then come off by pulling it up & rearward.. [if your tractor is a pony start the pony will have to come off also].. If electric start just remove what gets in the way..
~Don't loose the fan shaft to governor gaskets as those are also fan gear position shims.. They must go back at the same thickness..
[email protected]
R MOORE
03-14-2004 14:07:33
 Re: Re: Re: Re: 730D CRANKSHAFT in reply to Clooney , 03-14-2004 10:12:34
On the lh side of the governor is a piece that looks like it comes out of the injector pump.It has a part number on the sideR20871R.How do i get this off?Thank you.
Clooney
03-14-2004 15:45:55
 Re: Re: Re: Re: Re: 730D CRANKSHAFT in reply to R MOORE, 03-14-2004 14:07:33
R Moore, that is the governor lever housing.. It just unbolts, then twists out a little, then pulls off forward. Getting it off is not hard, getting it back on & engaged in the governor slotted pivot inside the governor is harder.. The lever that sticks out of the rear of that side housing MUST properly engage the governor when reinstalling. You will know it's correct when you can move the speed control & reach inside the governor lever housing & feel the lever inside move both directions..
[email protected]
R MOORE
03-14-2004 15:51:11
 Re: Re: Re: Re: Re: Re: 730D CRANKSHAFT in reply to Clooney , 03-14-2004 15:45:55
Thank you very much.Thrust washers should be in tomorrow.Going to try to put them in tomorrow evening.Wish me luck.
Clooney
03-14-2004 15:57:40
 Re: Re: Re: Re: Re: Re: Re: 730D CRANKSHAFT in reply to R MOORE, 03-14-2004 15:51:11
R MOORE, grease that inner thrust washer up good [on the bearing housing side only] when installing & be sure to keep the crankshaft held over to the left so that new thrust washer stays put & doesn't fall out of position & end up like your old one... Good luck & go slow as you really don't want to do that job over again..
[email protected]
