Clooney - paint work in the picture you posted
JC
03-14-2004 06:21:21
Clooney, Beautiful paint work in the picture you posted of the fan blades. This unstyled "D" is the first tractor I've restored. It's been such a major project {8 months} and I've been so anxious to get it running that I've started to re-assemble it without painting the pieces like the governor assy, tappet case, air intake casting, main case etc.
They have all been thoroughly cleaned, but I think I should start painting before I assemble anything else - #@$%&^*($%^&*$%^&*$%^&*%^&*.
Questions:
1. Do you paint all of the individual pieces before assembly?
2. Brush or spray?
3. Who's primer, paint, hardener, thinner, etc do you use?
4. Classic Green or Ag-Green colour for unstyled 'D's?
5. How do you de-grease after cleaning, before painting.
6. Sand-blasting - Do you sandblast assembled tractors or only individual pieces that have been dis-assembled?
Any suggestions and /or a website URL would be much appreciated by this novice JD restorer!
JC
Clooney
03-14-2004 07:03:49
 Re: Clooney - paint work in the picture you posted in reply to JC, 03-14-2004 06:21:21
JC, lets answer your questions one at a time..
1. Do you paint all of the individual pieces before assembly?...>>> Answ, I paint most small pieces off the tractor & on the larger ones I cut-in or paint the under side or edges before assembly..
2. Brush or spray?...>>> Answ, always spray [except bolt heads or nuts that I brush paint after assembly].. I use a small Sata mini jet touch up gun for most small parts..
3. Who's primer, paint, hardener, thinner, etc do you use?...>>> Answ, it varies as I keep trying new things or improve on old ones.. After initial sand blasting or power wire brushing I treat with a Phosphoric acid rust killer to kill the rust in the metal pores, then sometimes will spray on an initial coat of PPG DX 1791 Wash Primer as an adhesion promoting sealer, then a coat or two of PPG DP 40-LF epoxy primer [that DP 40 LF is a great sealer & substrate for most color coats & doesn't seem to shrink in time like most standard primers]. After the DP 40 LF I usually wipe down with a scotch pad then wipe with enamel reducer then shoot a few coats of color coat.. If shooting pitted metal or to help straighten out low spots in a panel I will sometimes use PPG K-36 urethane primer surface as a sanding coat, then another thinned coat of DP 40 LF as a sealer before final color coats.. -Painting is kind of a personal thing & a person kind of keeps what works & discards what doesn't work.. As you will find when you start your painting project the above products are very expensive so you might try to find cheaper alternatives.. There are some generic products that do work quite good but I have been reluctant to change do to what I use working so good..
4. Classic Green or Ag-Green color for unstyled 'D's?....>>> Answ, either or neither, Depends... They both look good.. On most I use a PPG or Dupont acrylic enamel but on some I also use Deere classic or AG green.. I think that D was done with classic green...
5. How do you de-grease after cleaning, before painting....>>>> Answ, that depends on the amount of grease or other dirt... If the metal is already clean I use enamel reducer.. If it's real greasy or dirty I use steam, or heavy duty grease remover & hot water.. Sometimes I use kerosene first to soak the tractor or even diesel fuel to soak it for a month while waiting to work on it or while playing with it before work starts..
6. Sand-blasting - Do you sandblast assembled tractors or only individual pieces that have been dis-assembled?....>>> Answ, I NEVER sand blast a complete tractor,, most times I don't even sand blast the main case or trans case.. I do sand blast most small or removable pieces either in my blast cabinet or outside in my remote blast area.. Don't blast anything you won't completely disassemble afterwards.. Also don't blast around where you intend to paint.. Rotary wire brushes, small wire brushes on a die grinder, needle scalars all work good on the main cases & trans cases..
7. Any suggestions and /or a website URL would be much appreciated by this novice JD restorer!....>>> Answ, this site is a good one [use the archives,, single words ONLY,, like PAINT, or SAND, or PRIMER, etc.. There are a few other sites but in fairness to Kim I won't post them here..
[email protected]
Paul.D.Canada
03-14-2004 12:52:31
 Re: Re: Clooney - paint work in the picture you po in reply to Clooney , 03-14-2004 07:03:49
Clooney, is the fan blades supposed to be yellow on all D's? I would like to know so when I paint my D. Thanks Paul.
Clooney
03-14-2004 15:53:13
 Re: Re: Re: Clooney - paint work in the picture yo in reply to Paul.D.Canada, 03-14-2004 12:52:31
Paul, on the unstyled D the rear of the fan was painted yellow with a brush after the tractor was painted green during assembly, at least up through the end of 37.. It might have been painted yellow on the back much later than that but I only researched up through the end of 37.. The brush painting looks kind of tacky so most people just paint the entire rear of the fan yellow.. You really need to research your year & model to be sure before painting..
[email protected]
