J Patton: Attach a piece of masking tape to the fan-shaft and draw a bold horizontal line on the tape. Rotate the flywheel exactly one full revolution by hand while observing how many rotations {and / or part revolutions} the fan shaft turns. My I.T manual shows 975 RPM at full throttle with the engine working {1115 RPM no load}. Multiply 975 RPM times the number of revolutions and partial revolutions you measured above and that would be the fanshaft speed at full throttle. examples 2 turns would be 1,950 RPM 1 turns would be 975 RPM 3/4 turns would be 731 RPM etc etc etc etc. Since you probably won't be running at full throttle, reduce the RPM accordingly. I'd guess 500-600 RPM but that's only my guess. Next you need to measure the fan-shaft pulley diameter and the alternator pulley diameter to calculate the alternator RPM. example: 5" fan-shaft pulley divided by 3" alternator pulley would be 1.666 times fan-shaft speed. {note, I guestimated these sizes}. So Engine RPM times fan-shaft ratio times pulley ratio = alternator RPM. Example - 600 RPM x 2 fan-shaft ratio x 1.666 pulley ratio = 1999.2 RPM. I've seen a website that shows output for GM alternators at different RPMs. You need to know the exact model to get a reliable number. I can't find the URL at the moment but someone here on YT will undoubtedly find it. JC
