Clooney, generator bench testing
Mike
03-13-2004 16:48:03
I tested it like you said, and it spun pretty fast, when I unhooked the ground to the field, it stopped suddenly and went in reverse, but turned alot slower, I cant see a delco tag but it has to be one on this JD 620, I had to do some major overhaul on this becauase on field had broken wires in it, did I do somthing wrong?
Clooney
03-13-2004 18:27:04
 Re: Clooney, generator bench testing in reply to Mike, 03-13-2004 16:48:03
Mike, it sounds like you have something wired incorrectly with the field or you have the field hooked up backwards, or you have a field winding flipped over, or ???..... .
~To go much farther-- can you identify the generator? Is it a 2 brush or 3 brush generator.. Is the field winding hooked to the [A] post on one end & the [F] post on the other?.. If not, how is it wired?.. Are you sure you are powering the [A] post & not the [F] post [the {A} post is supposed to be the larger of the two posts but you never know what has been done to the inside of that generator at one time or the other..
[email protected]
Mike
03-13-2004 23:01:22
 Re: Re: Clooney, generator bench testing in reply to Clooney , 03-13-2004 18:27:04
Hey Clooney, I had a field reversed wired, and changed it and now testing like you had first described, thanks a ton, I never had worked on one of these before and you helped alot, thanks to all who replied.
Clooney
03-14-2004 05:18:24
 Re: Re: Re: Clooney, generator bench testing in reply to Mike, 03-13-2004 23:01:22
Mike, you're welcome... It sounds like you have it now & are good to go..
[email protected]
Mike
03-13-2004 21:17:24
It is a two brush unit, I may have hooked them up in reverse, I will have to look at that tomorrow, I know I have the fields installed with the wires toward the back cover near the brushes, I know that I have one wire hooked up to the screw that holds one of the brushes , plus the brush wire, so two wires on that side and just the brush on the other side, Mike
buickanddeere
03-13-2004 19:29:45
It's possible the field winding maybe shorted to the generator case.
