Delco starter # 1108950 For early JD60 (Help Cloon
Chris Armes
03-13-2004 14:14:01
I am having trouble locating a comutator plate and ring. I'm told they are no longer available. I really do not want to go and buy a rebuilt one as they are a little salty. I have two starters which I had checked, the fields and armatures are good as well as the nose cones. All I need is the comutator plate to have a good starter. Any help as far as ideas on maybe other parts and brush holders that I could retrofit onto the back plate or maybe some one that has a rebuildable for sale would be a big help.
Thanks in advance:: Chris in Fountaintown
mike
03-13-2004 18:02:50
 Re: Delco starter # 1108950 For early JD60 (Help C in reply to Chris Armes, 03-13-2004 14:14:01
would any parts off an A starter work, I have one tore up for parts.
Clooney
03-13-2004 18:30:51
 Re: Re: Delco starter # 1108950 For early JD60 (He in reply to mike, 03-13-2004 18:02:50
Mike, the late [A] from about 1948 up should be the same...
[email protected]
Clooney
03-13-2004 16:15:50
Chris, are you talking about the commutator end frame? If so what's wrong with yours? If it a brush, or brush holder, or bushing problem in a lot of cases those can be repaired..
~If you must have a new or different one probably the cheapest way is to find a scrap starter at a tractor scrap yard [I believe the Deere 70 gas uses the same starter end frame].. You can also try some local starter shops to see if they might have one laying around..
~You might also try a few on line tractor electrical shops like Ag Services Phone: [716-937-6618], or Classic Generator Phone: 817-473-1448.. Or even try placing a WANTED ad in this or other on line tractor "For Sale" ad sites [those sometimes work pretty good]..... ..
[email protected]
F-I-T
03-13-2004 16:00:02
Chris:
You might try Kenneth at Classic Generator (Phone: 817-473-1448 ). He works on lots of older stuff. I bet he would have the parts.
Frank
