420 Final Drive Seal
Henry J
03-13-2004 05:46:50
I have always wondered just how the final drive on a 420 seals up with no seepage where the quill (think that is what it is called) bolts to the housing and the shims are sandwitched between it and the housing. After running mine about 150 hours it has dust collecting on the oil that is obviously seeping out through the shim packs. It is not dripping but I am the sort of person that can let things like that get my attention.
I am thinking of drying the area up and putting a coat of something like JB weld around the bottom half and finish before painting?
What do you think?
Thanks
Henry J
03-13-2004 13:14:04
 Re: 420 Final Drive Seal in reply to Henry J, 03-13-2004 05:46:50
Wayne
I have had them apart and shimmed them up to JD specs.
A long while back I took advise from this board and put two seals (From Carquest) in each quill. Also packed the space between the seals with grease.
Before I did this, oil would pour out when on a steep side hill. Anyway, they now show just enough seepage to collect dust at the shim packs. The axel seals have completely cured the leaks there.
Hmmmm, seems like you may have been the guy that gave me the cross over number for the seals lol.
tom
03-13-2004 15:57:16
 Re: Re: 420 Final Drive Seal in reply to Henry J, 03-13-2004 13:14:04
Gentlemen,
Since we are on the topic of final drives and talking about Dubuque's, i thought when i changed the leaking seal on my PTO, and the now fixed hydraulics [with all new seals], i too thought the oil would leave. However, it is still there...could this be leaking from the final drives? If so, is the solution for the MT the same as the 420, or does someone else have an idea?
thanks and i hope you get your problem resolved henry j...thanks wayne,
tom
Wayne in Tn.
03-13-2004 06:54:18
Henry J, I have often wondered the same thing. How could steel shims not leak? But evidently they do seal by tightening the bolts and "mushing" together. It's possible the seal is bad in the quill, and oil is running back underneath or maybe one of the shims has been damaged or bent. Those things are very fragile, especially the thin ones.
I would completely remove the quill and install a new seal (very reasonable) then clean up all the shims and set the end play on the axel, you may be able to take some of the shims out.
The hardest part is removing the wheel and hub. If yours has the "spin out" rears, it will be a little harder to remove the hub. After removing the hub, I would sand the axel real good, to avoid damage to a new seal when going back on with the quill.
Dave- Ia
03-13-2004 10:48:58
 Re: Re: 420 Final Drive Seal in reply to Wayne in Tn., 03-13-2004 06:54:18
Wayne, do you have any tips on removing the hub for the spinout wheels? I am getting ready to replace the seals on my 430 W. I am guessing a good puller and some heat but do you have any other suggestions? I just finished the clutch and that went very well. It was like I thought it might be. The clutch fingers were out of adjustment, probably not done correctly the last time it was apart. I did put new clutch plates in though.
Wayne in Tn.
03-13-2004 12:52:04
 Re: Re: Re: 420 Final Drive Seal in reply to Dave- Ia, 03-13-2004 10:48:58
Dave, On the spin-out hubs, I have never had any problem getting them off (maybe just lucky) after removing the big nut, a couple of whacks on the back side and they came off. If yours are stubborn, a puller may be necessary, but that axel spline is tapered and should not be too hard to get them off.
Phil
03-15-2004 05:50:28
 Re: Re: Re: Re: 420 Final Drive Seal in reply to Wayne in Tn., 03-13-2004 12:52:04
I did have trouble on my 430W pulling the tapered hubs with spin-out wheels.
I borrowed the biggest gear puller I ever saw that was made to pull gears on big printing presses. It must weigh 30-lbs. I used a 1" breaker bar with a 4-foot pipe extension and jumped up and down on the end. (I weigh 200-lbs.) I then hit the puller with a 5-lb. hammer and when the hub came off it sounded like s shotgun going off and shot half way across the barn.
Yes I did use penetrating oil and some heat.
Needless to say, don't stand too close if yours is this tight.
Phil
