80-830 brakes overhaul?
robert
03-13-2004 04:26:56
my jd service book says to lift up platform.I looks to me unit should clear straight out sideways and clear fender shirt.has anyone got brake unit off case without messing with dash and platform lift? (need new seals on drum shaft and pads while at it).
Jeff (nj)
03-14-2004 09:03:06
 Re: 80-830 brakes overhaul? in reply to robert, 03-13-2004 04:26:56
Robert, Please let me know how you end up doing this job. Maybe you can save me alot of work next time I do this.If there is an easier way,I could'nt figure it out and apparently the mechanics at JD at the time could'nt either.Sorry if I gave you some bad info.
Ralph - Wi
03-13-2004 13:10:57
Its a couple of years ago, but I think we did the brakes on my 820 without removal of the platform or the brake pedals. After I got the pedals through the platform, my mechanic gave me a hand. I could not have lifted them into place from beneath the tractor. Sitting on the ground and getting them above shoulder height was all I could do.
Brandon
03-13-2004 12:04:21
There is a nut that holds the brake lever on. If you remove the instrument panel, and the "kick plate" or whatever you want to call it, you can probably see those nuts. If you are a contorsionist, and have the right wrench, you can probably remove those nuts to get the levers out.
It isn't easy, and you may learn a few new words, but I managed to do it without lifting the platform.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Jeff (nj)
03-13-2004 06:08:59
Robert, I just replaced my pads and seals on my 830. You can do the pads easy enough, but the whole platform has to come off to replace the seals because the brake levers will not clear the platform when pulling the unit off the shaft to get at the seal.You have to follow the book on this one. A chain hoist comes in handy for this job. Have your drums turned also.
